Forum topic by Vrtigo1 | posted 02-04-2011 06:06 AM | 3058 views | 0 times favorited | 16 replies | ![]() |
I have a Ridgid jointer that has vibration issues. When it runs, it vibrates quite a bit. Not so bad as to be like a washing machine with an unbalanced load, but enough to make me think that it’s vibrating more than it should. I checked the manual and didn’t find any suggestions there. Does anyone have any suggestions as to what I should check? I know for band saws and other things, changing the belt can help a lot. Would that be the case here as well? If so, how should I go about determining what belt I should buy? |
16 replies so far
#1 posted 02-04-2011 06:44 AM |
make sure the machine is siting flat and not rocking on the floor. then check your pulley alignment by hoilding a straight edge agaisnt both of them at the same time they should contact the straight edge evenly if not you can pull and push the pulleys into alignment. Then while you got the belt off check it for cracks or excessive set if its bad go ahead and upgrade to the link style they last forever. then if it still vibrates try adding wieght to the machine some bags of sand or concrete in the base. as far as buying a new belt just take the old one to a auto store they will measure it and give a new one or upgrade and use the old one as a guide as far as how many links to use -- As Best I Can |
#2 posted 02-04-2011 02:00 PM |
I would guess the pulley alignment as well. I have the same machine and it just hums with no discernible vibration. |
#3 posted 02-04-2011 03:57 PM |
If those suggestions don’t work then you may have some pulleys that are not concentric and then I would go with machined pulleys and a link belt. One other thing you may check is lay a straight edge across the bed and measure the run out on the cutter head. -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#4 posted 02-04-2011 04:29 PM |
I have the same jointer. If everything else checks out get a link belt. I just put one on mine and it made a huge difference. |
#5 posted 02-04-2011 04:40 PM |
Remove the belt and “run” the motor to check for vibration caused by the motor. -- Carl in SC |
#6 posted 02-04-2011 04:48 PM |
Check list—- If everything seems good, replace the blades – both of them or all three, never just one. These should tell you where the problem exists -- David in Damascus, MD |
#7 posted 02-04-2011 05:18 PM |
If I replace the belt, are they pretty universal other than length? |
#8 posted 02-04-2011 05:26 PM |
Vrtigo1—That’s one of the beauties of link belts … you can make it any length you need. —Gerry -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#9 posted 02-04-2011 05:33 PM |
Good suggestions. First thought was that I wonder if one of the blades/knives weighs a few grams more than the other two. |
#10 posted 02-04-2011 05:48 PM |
I’m betting belt, too. The idea of removing it, and seeing if that solves the problem is spot on. There are different profiles of link belt, but … bringing the old one with you, or … simply having it in front of you (for online ordering) should be all you need to do. It’s my plan to put link belts on all the tools in my shop that will accept them. When I get around to it, of course ;-) -- -- Neil |
#11 posted 02-04-2011 05:59 PM |
Link belts at harbor freight any good? |
#12 posted 02-04-2011 06:02 PM |
When I bought my small jointer, I bought used. The guy that I bought it from had a chipped blade and only sharpend the one blade. These have to be matched or it can get dicy. -- David in Damascus, MD |
#13 posted 02-04-2011 06:05 PM |
Vrtigo1—I think the HF link belts are OK … I replaced the belt on my bandsaw with a HF link belt, and it performs just fine. —Gerry -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#14 posted 02-04-2011 09:59 PM |
The HF belt worked well for me. |
#15 posted 02-07-2011 05:29 PM |
Without actually seeing the jointer I think the pulley alignment shouldn’t cause vibration, although stamped pulleys will. They can be balanced if you are patient. If you want to know how PM me and I’ll go thru the steps with you, it would save you some money over machined pulleys. Replace the belt especially if it has a chunk out of it. I don’t know anything about the HF belts other than they are about 10 percent less than the cost of the name brands. I know there are some on this board that knock HF just because. To each their own! -- BobG, Lowell, Arkansas--------My goal in life is to be the kind of person my dog thinks I am! Make more saw dust!! |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4901 |
6691 |
28041 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6227 |
1387 |
Focus on the Workspace
2153 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8842 |
