Painting a project with an HPLV gun
Forum topic by hianupam posted 02-04-2011 09:39 AM 1719 views 0 times favorited 5 replies Add to Favorites Watch
View hianupam's profile
20 posts in 2618 days
02-04-2011 09:39 AM
I have been meaning to try painting with an HPLV gun and wondered if i can get feedback on a couple of points:
I have a 30 gal air compressor and a HPLV gun (not gravity fed)
I want to paint some shelves that I plan to build in our closet.
What kind of paint should I be using (open to both water based or oil based)?
How much should I thin it?
What sized needle should I use?
Thanks in advance.
-- Measure Twice, Cut Once
5 replies so far
View okwoodshop's profile
448 posts in 3110 days
#1 posted 02-05-2011 03:13 AM
I use mine to spray thinned water based paint. About a cup of water to 3/4 of a quart of paint. I use a quart canning jar and save what is left over(for a short Time). You will have to experiment depending on your paint type.
View Pop's profile
427 posts in 3881 days
#2 posted 02-05-2011 04:19 AM
okwoodshop is right the paint must be thinned. It also helps if you have a powerful 4 stage turbine. I have a Fuji 3 stage turbine. All I spray is shellac and lacquer.
-- One who works with his hands is a laborer, his hands & head A craftsman, his hands, head & heart a artist
View ChunkyC's profile
856 posts in 3189 days
#3 posted 02-05-2011 04:43 AM
Do you mean HVLP, High Volume Low Pressure?
-- Chunk's Workshop pictures:
View Tim_456's profile
170 posts in 3530 days
#4 posted 02-05-2011 04:46 AM
I’m also interested in the responses to this in addition:
The brand/type of paint
The air pressure used when spraying
#5 posted 02-07-2011 06:23 PM
All thanks for the replies. @Chunk thanks for the correction. I did mean HVLP. I have a 1.7 mm needle. I am more partial to oil based paints. Any suggestions on brands and places to get them in and around houston?
