Question about Woodsmith/Shop Notes router table
Forum topic by Brett posted 02-04-2011 01:34 AM 3337 views 1 time favorited 8 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2710 days
02-04-2011 01:34 AM
I’m considering building a router table using plans from the Woodsmith Shop website:
http://www.woodsmithshop.com/download/111/111-routertable.pdf
The table is built with a base of 3/4-in MDF and two “covers” of 1/4-in hardboard (basically, the two hardboard layers are glued onto the MDF and the assembly is banded with hardwood and covered with a sheet of plastic laminate).
Why this design? Wouldn’t it be better to use a 1/2-in piece of MDF instead of the two hardboard sheets? What’s the reason for this design?
-- More tools, fewer machines.
8 replies so far
View TMcG's profile
TMcG
191 posts in 3027 days
#1 posted 02-04-2011 01:48 AM
They are all roughly the same pattern, a sandwich of some flat material with a top layer of low friction laminate, this one is a little different with the 3/4 ply and 2 hardboard layers but, I guess, achieves the same result, a flat rigid surface to mount the plate to.
-- http://wood.mcgivern.org
View brtech's profile
brtech
1029 posts in 2949 days
#2 posted 02-04-2011 02:33 AM
Yeah, that is weird. I’d be inclined to just use 1/2” MDF instead of the two hardboard layers. Hardboard doesn’t have any grain, so lamination isn’t helping.
View Belg1960's profile
Belg1960
1072 posts in 3092 days
#3 posted 02-04-2011 02:59 AM
can’t help with the why but I hope you are going to build the version with the door/drawers as otherwise it seems like missed opportunity for some all important storage.
-- ***Pat*** Rookie woodworker looking for an education!!!
Brett
#4 posted 02-04-2011 05:38 AM
I was leaning toward the non-cabinet version, because I”m fairly new to woodworking and it seems a more attainable goal. I’m open to suggestions for other router tables that are not too complicated to build.
View thiel's profile
thiel
387 posts in 3319 days
#5 posted 02-04-2011 05:51 AM
Hmmm… the plans say 3/4 inch PLY, not MDF, which could be the reason for the hardboard…to eliminate even the grain fluctuations in the ply?
I went with two layers of 3/4 MDF, then laminate right on top of that. Can’t help feeling like I overdid it.
-- Laziness minus Apathy equals Efficiency
Brett
#6 posted 02-04-2011 04:55 PM
Good point, thiel. I forgot that it says ply, not MDF.
View EEngineer's profile
EEngineer
1103 posts in 3640 days
#7 posted 02-04-2011 05:51 PM
As a matter of fact, my first though t was that this seems a little underbuilt. Like Thiel, my top was made of two sheets of 3/4” MDF laminated, and I don’t consider it overbuilt at all. If you are gonna hang a big router under it, you probably need that to keep the table top from sagging under the weight of the router.
View surfin2's profile
surfin2
51276 posts in 3163 days
#8 posted 02-04-2011 08:10 PM
I tried to figure out the reasoning behind this and couldn’t. If I was to use hardboard with MDF or Ply I would put 1 piece on both sides…
I tried to figure why Norm used 1/2 + 3/4 for his top???
Was it for weight reasons or biscuits reasoning???
-- Rick
