Easy technique for butt joint on a curve?
Forum topic by scottkeen posted 10-06-2017 04:14 PM 588 views 0 times favorited 10 replies Add to Favorites Watch
View scottkeen's profile
scottkeen
48 posts in 1125 days
10-06-2017 04:14 PM
I need to butt joint a 1-1/2” wide square cut piece to a curved piece.
Is there some easy technique to cut the 1-1/2” piece so that it butt joints to the curved piece perfectly?
See photo
10 replies so far
View BobAnderton's profile
BobAnderton
283 posts in 2989 days
#1 posted 10-06-2017 04:30 PM
You want to scribe the curved shape onto the other board and then cut to that scribed line. Here’s an example.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View Nubsnstubs's profile
Nubsnstubs
1422 posts in 1929 days
#2 posted 10-06-2017 05:00 PM
I would just find the angle, set up a miter saw, cut and butt it. The piece is too small to make a difference, is not going to be seen and you used the word, Perfect. It dosen’t happen in woodworking except for the woodworking TV heros some people have… ........... Jerry (in Tucson)
View Woodknack's profile
Woodknack
12430 posts in 2579 days
#3 posted 10-06-2017 05:07 PM
For rough work that won’t be seen I would sketch the curve and cut it with a jigsaw or bandsaw.
scottkeen
#4 posted 10-06-2017 05:12 PM
Thanks guys. I forgot all about scribing. I was going to just sketch it and rough cut it to fit. As ya’all say, it’s a piece that won’t be seen.
It’s sandwiched between the top of this table, and the underside. Rather than use another whole sheet of 3/4” plywood for the middle layer, I’m putting in 1-1/2” strips in the middle layer. Makes it lighter too.
View oldnovice's profile
oldnovice
7325 posts in 3566 days
#5 posted 10-06-2017 05:39 PM
It appears that all of the “scribes” above concur that scribing is the solution!
View Dustin's profile
Dustin
594 posts in 939 days
#6 posted 10-06-2017 05:43 PM
Nice idea for removing excess weight, and I’m super jealous of whoever is receiving that awesome poker table!
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
View bondogaposis's profile (online now)
bondogaposis
5088 posts in 2550 days
#7 posted 10-06-2017 06:06 PM
Scribe it and cut to the line on the band saw.
-- Bondo Gaposis
oldnovice
#8 posted 10-06-2017 08:16 PM
There is one harder way!
Use a pattern bit in a router, run the bearing along the desired curve and the cutting portion along the desired matching piece!
Told you this was going to be harder!
scottkeen
#9 posted 10-06-2017 08:19 PM
Along those same thoughts, I was thinking to build a pantorouter and a template of the curve, so I could cut it again for future tables.
http://woodgears.ca/pantorouter/index.html
scottkeen
#10 posted 10-08-2017 08:43 PM
I’ve built about 2-dozen poker tables. This is the 2nd one I’m doing this way with 1-1/2” thick base and and a “grid” for one of the layers to build up the thickness rather than using a full sheet of plywood. The other tables I’ve built have no base, just a table playing surface and padded armrest rail with folding legs attached to the bottom of the playing surface. More for lightweight portability, lower cost, and just fold the legs and store. This one with a thick base and double pedestals with legs is going to be more like furniture.
You can see the grid in this photo and the edge banding. I just edge-banded the dealer cut-out in the photo, but did the entire edge around the table base.
This poker table I’m making for myself. :-)
Nice idea for removing excess weight, and I m super jealous of whoever is receiving that awesome poker table!
- Dustin
