Bolt size for Attaching Fence to Delta Bandsaw
Forum topic by Carl Webster posted 02-03-2011 06:40 PM 3351 views 0 times favorited 5 replies Add to Favorites Watch
View Carl Webster's profile
Carl Webster
82 posts in 3038 days
02-03-2011 06:40 PM
I have a 14” Delta bandsaw model # 28-275. I need to know the bolt size and threads/inch that holds the fence guides to the table. The bolt size appears to be 1/4 inch but I don’t know if the threads are course or fine. I guess my only choice is to buy 4 bolts of each (course/fine).
Thanks.
-- Carl in SC
5 replies so far
View brendandahl's profile
brendandahl
9 posts in 2929 days
#1 posted 02-03-2011 07:22 PM
I don’t have a delta bandsaw but in my Kreg bandsaw fence manual it specifies the delta bolt as:
FT4185 2 1/4-28×1-1/4” Hex Bolt (Delta Mount)
http://www.kregtool.com/prodimages/kms7200%20%20band%20saw%20fence%20manual.pdf
View hairy's profile
hairy
2783 posts in 3772 days
#2 posted 02-03-2011 08:12 PM
My Delta bandsaw table is drilled and tapped to 1/4” x 20 tpi. That’s coarse thread.
-- My reality check bounced...
View skippyland's profile
skippyland
158 posts in 2931 days
#3 posted 02-03-2011 08:28 PM
Carl, be careful on this one. I needed a replacement bolt for my 12” Jet. After no success, I discovered I needed METRIC and reverse thread…best advice: locate a part explosion in the manual. Good luck
-- Skip from Batavia, purveyor of fine and exotic sawdust & chips.
Carl Webster
#4 posted 02-03-2011 09:56 PM
Thanks for all your replys. I took a risk and bought 1/4 x fine thread (28 tpi) bolts and they fit. I knew the threads were SAE and not metric, because the band saw is an older Delta saw made in Pittsburg, PA. I happened to have some 1/4 ’- course threaded bolts that fit the hole, but the thread was wrong.
Based on hairy’s input, I guess Delta does’t have a “standard” for these bolts.
-- Carl in SC
hairy
#5 posted 02-04-2011 01:10 AM
My bandsaw was built in the 1940’s. Delta Milwaukee. Fine threads do give a better grip than coarse.
