Cheap Table Saw Inserts
Forum topic by juniorjock posted 269 days ago 439 views 1 time favorited 11 replies Add to Favorites
View juniorjock's profile
juniorjock
356 posts in 294 days
269 days ago
Topic tags/keywords: jig tip tablesaw
I saw this on AmericanWoodworker. It’s a great idea.
Commercially made zero-clearance inserts cost about $20. I make my own for less than $3 from 3/8-in.-thick polyethylene cutting boards, which are flat and rigid. A 14-in. x 17-in. cutting board ($10 at a discount department store) yields four inserts. After rough-sawing the blank on my bandsaw, I attach the saw’s insert with double-faced tape. Then I rout the blank to final size using a flush-trim bit. I drill 11/64-in. pilot holes and install the adjustment screws, which are 3/8-in.-long #10-24 Allen-head set screws (about 40 cents each at a hardware store). Raising the blade through the polyethylene to cut the zero-clearance slot leaves plastic curls around the edge. They’re easily removed by filing or sanding.
-- Make things with wood.
9724 posts in 350 days
269 days ago
Nice tip. I will have to keep this in mind the next time I replace my zero clearance plate.
juniorjock
269 days ago
The way I see it, with the cost this low, I could make a different insert for all the basic dado set ups (1/4, 3/8, 1/2, etc.) The dado insert that came with my Grizzly G0575 table saw is a “one size fits all” and there’s way to much space when using one of the smaller dado set ups.
View John Gray's profile
John Gray
863 posts in 414 days
269 days ago
Thanks for the post I’m in the process of making some inserts too.
View David Harms's profile
David Harms
43 posts in 271 days
269 days ago
Thanks for this, a table saw book I have suggests making them out of MDF but I like this idea too.
-- David - Houston, Texas.
View Dano's profile
Dano
215 posts in 560 days
268 days ago
neat idea, thanks, guess I need to make a trip to Wally World…
-- Dan in Central Oklahoma, Able to turn good wood into saw dust in the blink of an eye!
teenagewoodworker
2126 posts in 296 days
268 days ago
that’s a good idea. i probably would have bee the first person to buy them at someplace like Rockler. so you’ve just saved me a load of money. thank you.
juniorjock
268 days ago
Yes it sounds like a great idea, but please note that I haven’t actually tried this yet. But I plan to sometime this weekend and I’ll let everyone know how it does. Heck, for the money, how could you go wrong?
View rikkor's profile
rikkor
8362 posts in 403 days
268 days ago
Great tip JJ.
-- Maplewood, MN
View ChicoWoodnut's profile
ChicoWoodnut
731 posts in 344 days
267 days ago
I make mine exactly that way using luan plywood. Rout them out an put set screws in. It takes about 15 minutes to make one.
View tomd's profile
tomd
115 posts in 298 days
267 days ago
I’m with Chico, I use luan too, I usually make up about 6 at a time and throw them away as they wear out, I also make them for my bandsaw, and my router table. The router table you can make several sizes of bit hole sizes.
-- Tom D
View Suz's profile
Suz
51 posts in 285 days
266 days ago
I’m lucky enough that I can make my ZCI’s out of 1/2” MDF.
-- Jim
Bookmark And Share This Page
