Stability of Hard Maple
Forum topic by Bohaiboy posted 10-05-2017 07:11 PM 911 views 0 times favorited 21 replies Add to Favorites Watch
View Bohaiboy's profile
Bohaiboy
76 posts in 2031 days
10-05-2017 07:11 PM
I am using one side of hard maple as a substrate for mesquite veneer. The maple side will be the side that drawer hardware attaches to for a chest. Was curious as to the movement stability of hard maple. I have thought of baltic birch also (very stable) but not sure how edge banding that would look (of course I have to edge band the maple also).
TIA
-- Tim, Houston, TX area
21 replies so far
View Loren's profile
10477 posts in 3884 days
#1 posted 10-05-2017 07:34 PM
I’m guessing it is plywood. The inner plies
probably determine its stability more than
the thin face veneer would. In any case,
plywood is generally quite stable dimensionally.
As you’ve probably noticed larger pieces
have a tendency to “potato chip” to varying
degrees. MDF and particle board tend to
be flatter, if stored flat.
Bohaiboy
#2 posted 10-05-2017 07:45 PM
The maple is solid wood.
View jonah's profile
jonah
1972 posts in 3535 days
#3 posted 10-05-2017 08:21 PM
Why would you edge band solid wood?
View Aj2's profile
Aj2
1949 posts in 2034 days
#4 posted 10-05-2017 08:30 PM
I wouldn’t count on Hardmaple for stabity. Listen to the voice that told you to ask this question.
-- Aj
View bondogaposis's profile
bondogaposis
5150 posts in 2588 days
#5 posted 10-05-2017 08:34 PM
Shouldn’t be a problem if you orient the grain in the same direction. Generally you would veneer both sides of the maple to balance it. Don’t edge band solid wood, it serves no purpose.
-- Bondo Gaposis
19603 posts in 2093 days
#6 posted 10-05-2017 08:36 PM
I would think hard maple at least as stable as mesquite, but not stable enough to edge band with grain running in the opposite direction. If you can band it with matching grain direction, I would think it would be fine.
View DS's profile
DS
3045 posts in 2657 days
#7 posted 10-05-2017 09:07 PM
Veneering only one face will destabilize even the best plywood or solid wood.
Be sure to use a stabilizing back face veneer and you could use nearly any substrate and get decent results.
Given the choices you listed, I would be choosing the Baltic Birch and filling any edge voids before banding.
View EricTwice's profile
EricTwice
248 posts in 770 days
#8 posted 10-05-2017 09:11 PM
It might be ok if you veneer both sides at the same time. If you do not do this I will guarantee problems.
hard maple is not that stable, veneering will add stress on one side. If you do both sides, you are sealing the wood in.
this should actually help as long as the grain all goes the same way.
edge banding will be fine as long as the grain goes the same direction.
-- nice recovery, They should pay extra for that mistake, Eric E.
Bohaiboy
#9 posted 10-05-2017 09:16 PM
In this case, AI dont want the maple to show thus the edgebanding. I am not restricted to the thickness of the edge banding as I have to make it myself. I have not been able to find mesquite veneers of any sort.
View bold1's profile
bold1
310 posts in 2084 days
#10 posted 10-05-2017 09:21 PM
Erictwice, may I ask why you think hard Maple isn’t stable?
View ColonelTravis's profile
ColonelTravis
1953 posts in 2131 days
#11 posted 10-05-2017 10:39 PM
I’ve seen it but it’s rare. My guess is for at least two reasons:
1.) Most sawmills cut them in mantle slabs, 8/4 or 4/4 because that’s where the demand is.
2.) It’s got so many cracks and crevices and holes that if you cut really thin pieces of the good looking stuff it can be brittle and fall apart. The only way around this is to dump in epoxy and sawmill guys are not going to do that.
Sorry, confused here. If the hardware is on the maple side, where is the mesquite going? Why not use 100% mesquite?
Bohaiboy
#12 posted 10-05-2017 10:55 PM
Hi Colonel, this is part of a jewelry case and there will be a door that swings open on the mesquite side. Was trying to shave a few bucks here and there so i thought a substrate with a veneer might help. I have plenty of mesquite to veneer if need be. Here is a pic of the design in progress that maybe explains a tad more.
ColonelTravis
#13 posted 10-05-2017 11:22 PM
Forgive me, I feel like an idiot – you said you wanted the hardware on the maple side BUT! you wanted mesquite veneer. Is that veneer covering the drawer fronts and/or the entire drawer? Or is the veneer for that door?
Bohaiboy
#14 posted 10-05-2017 11:32 PM
The drawers are faced with birds eye maple and maple drawers. The rest of the drawing currently is 100% mesquite. The hardware is the drawer hardware (slides)
View AlaskaGuy's profile
AlaskaGuy
4989 posts in 2546 days
#15 posted 10-05-2017 11:39 PM
Hard Maple facts from a guy who know his stuff.
http://www.woodworkingnetwork.com/wood/wood-explorer/hard-maple
