| Forum topic by John's Woodshop | posted 269 days ago | 202 views | 1 time favorited | 9 replies | ![]() |
269 days ago |
If you were going to make a shaker style table 24” x 24” how thick would you make the top? How wide would you make the apron? How wide would you make the Breadboard edge? And how tall would you make the legs. (Tapered) It will be used for a kitchen table. My Mom is relocating and she needs a small table for her kitchen and she likes the shaker style tables. Thanks in advance for your help! John -- John -- Racine, WI -- Woodworking..."It's not just a Hobby, it's an Adventure" |
269 days ago |
Check these out at your local library http://www.amazon.com/Drawings-Shaker-Furniture-Woodenware-Vols/dp/0881507776/ref=sr_1_1?ie=UTF8&s=books&qid=1204217732&sr=8-1 -- Hope Never fails |
268 days ago |
Thomas Moser wrote an excellent book on building Shaker furniture. I’m sure a quick stop to your local library will offer many different resources to search. -- Tom's Workbench - http://tomsworkbench.com |
268 days ago |
Thanks for the advice guys. John -- John -- Racine, WI -- Woodworking..."It's not just a Hobby, it's an Adventure" |
268 days ago |
Here’s a table that I’ve made with my son Daniel. They were made without breadboard edges.
The top on this table is 22” square, the apron is 4” wide, the legs are 1 1/2” wide at the top and tapering to 1” on the inside surfaces (the outer edges are straight. The top is 3/4” or so but it has a taper to 1/2” at the edge which gives it visually thinner top. It does not have a breadboard top. It is 30” tall to the top surface which is about what my kitchen table is. If you make it a few inches wider you would have a little more room between the legs to get a chair and your grandmothers legs under the table. The aprons are 15” long Shoulder to shoulder (visually) But they have tenons into the legs It is 18” to the outside of the legs. Dan’s was made with white pine, I made mine out of cherry. Mine has a thicker top, closer to 1” thick. I didn’t see any need to planing the wood into sawdust. Any questions send me a message. -- Karson Southern Delaware karson_morrison@bigfoot.com |
268 days ago |
Hi John, most of the smaller shaker tables didn’t have breadboards as far as I know. The bigger ones had breadboards to help keep the boards aligned. Anyhow, here’s one I made recently. Shaker Table. The legs are a little beefy, but I made it that way because it’s going to have to hold up a fish tank. Also, the top is 3/4” thick and the apron is 4 5/8”. Karson’s table legs are a little more typical in proportion as far as shaker design goes. Todd Clippinger made a lovely hall/entry table that could be scaled to your specs. This is the one that inspired my version, but he says he doesn’t consider it shaker. Looks shaker to me, but I’m just an amateur. -- Carl Rast, Pelion, SC |
268 days ago |
True about no breadboard edges on shaker tables. I love shaker – clean lines, functional design and more beautiful (to me) than a bunch of gingerbread you see on a lot of furniture. Keep it simple, strong, built well, and designed for function first. To me that sums up shaker. |
268 days ago |
What degree of taper should I use on the legs for a standard height dining table? Thanks, -- John -- Racine, WI -- Woodworking..."It's not just a Hobby, it's an Adventure" |
268 days ago |
John: The table I made went from 2 1/8” at the top and tapered down to 1 1/8” at the bottom, but like I said I was going to put a fish tank on it, so thats why the larger size. I think Karsons formula of 1 1/2” at the top down to 1” at the bottom should be fine as long as you use a strong hardwood such as oak. It depends on what the load is going to be. If you make it from pine, I’d upsize the legs for a kitchen table. Hope this helps. -- Carl Rast, Pelion, SC |
265 days ago |
John, RJ |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1337 |
| Become a sponsor |
1778 |
| Become a sponsor |
123 |
| Become a sponsor |
371 |
| Become a sponsor |
108 |
| Become a sponsor |
Woodworking Trade & Swap
251 |
| Become a sponsor |
Coffee Lounge
1004 |
| Become a sponsor |
LumberJocks.com Site Feedback
284 |
