Old Craftsman 4 1/2 Joiner help
Forum topic by HuntleyBill posted 02-03-2011 02:01 AM 6448 views 0 times favorited 12 replies Add to Favorites Watch
View HuntleyBill's profile
HuntleyBill
114 posts in 3328 days
02-03-2011 02:01 AM
Hi Guys:
I have a Craftsman 4 1/2” Joiner-Planer I got from a neighbor (it was free so I couldn’t turn it down ). It is missing the guard but it does work, although it is a little loud. The blades were dull so I purchased a new set. I was surprised but Sears still has the blades available.
My problem, and question is does any one know how to adjust the blades on this? I got them close but one or both of the blades is slightly eschew. I can tell when I make several passes on a board the cut becomes increasingly crooked. I can compensate by alternately flipping the board end for end but then I am going against the grain and get tear out. When I try to “level” the blades I have a hard time lining it up when the blade assembly wants to rotate and I can’t find a way to hold the assembly firmly. Also, when I tighten the blade hold down screws, the blade shifts on me!!
I cuss a lot!!l
I can’t find a manual on this so does anyone know how I can adjust these. I know…I should buy a REAL planer but like I said, it was free!
Thanks for your help
Bill
-- If you think you can, or think you can't...your right!
12 replies so far
View D_Allen's profile
D_Allen
495 posts in 3022 days
#1 posted 02-03-2011 02:15 AM
I had one of those loud things for a while. It was also a freebie. I even made a guard for it but like you, I could never get the blades right and eventually threw it out. I don’t think that are built well enough to do anything but ‘get it close’.
Now I use my router and a split fence for jointing. Been happy with that ever since and I really don’t intend to get a jointer anytime soon.
-- Website is finally up and running....www.woodandwrite.com
View Tim Dahn's profile
Tim Dahn
1577 posts in 3803 days
#2 posted 02-03-2011 02:24 AM
Do you have a model number? Check out http://vintagemachinery.org/
HuntleyBill
#3 posted 02-03-2011 02:26 AM
The model # is 149-236221
Tim Dahn
#4 posted 02-03-2011 02:48 AM
I bet this manual is close enough 149-236221
View Loren's profile
10477 posts in 3886 days
#5 posted 02-03-2011 03:20 AM
Make a pair of small wood wedges about 3/8” square on the wide end.
Use these to hold the cutterhead still. It takes a bit of fussing. Softwood
is probably better for the wedges.
Setting knives accurately without some sort of magnetic jig (or hold-down
jig on a spring-loaded cutterhead) can be frustrating, but pull up a low
stool, get some good task light on the jointer and take your time
and you’ll get it done.
View brianinpa's profile
brianinpa
1812 posts in 3961 days
#6 posted 02-03-2011 03:59 AM
The blades being off by even a fraction of an inch is just as bad as it being off by a mile.
I use a dial indicator with a magnetic base. Like Loren said, “pull up a low stool” because the devil is in the detail. The 4” jointer I have uses three set screws to hold each of the three blades in place. I lock the center set screw and make the fine adjustments with the outer set screws until it is as perfect as I can get it. When you get a good measurement on one blade, repeat on the other two blades.
I remember seeing an in-depth write up on this subject in Wood Magazine but I can’t seem to find it right now.
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3345 days
#7 posted 02-03-2011 04:10 AM
Bill, have you got an old speaker? Heat to magnet with a propane torch just a bit more that you can touch. tap with a dead blow plastic hammer and the magnet will pop lose. DO NOT let it hit the floor. Cool and remove any glue left on the magnet and use this to hold the blade for tightening. The bigger the magnet the better. Hope this helps. Rand
HuntleyBill
#8 posted 02-03-2011 04:14 AM
Thank you for all your help. I don’t have a speaker to get a magnet off of but that seems like a really good way to hold the blade. Looks like the wedge idea may be the ticket.
Timbo. I cant get that link to open. The page just stays on “loading”.....it’s been loading for 10 min!
27250 posts in 4060 days
#9 posted 02-03-2011 04:35 AM
Bill, Here is an article by Tom Hintz that I found to be pretty helpful in setting jointer knives. What you have described sounds pretty normal to me. If the knives are off even a few thousands then you will have the problems that you are describing and, the knives will move when the gib screws are tightened unless you put downward pressure on the knives to hold them with a wood block or dowel while tightening the screws.
View canadianchips's profile
canadianchips
2616 posts in 3235 days
#10 posted 02-03-2011 05:06 AM
SIMPLE made guage.Plane a piece of hardwood about 12” long to use as guage.
Mark a line on the stick’s face where it crosses the edge of the outfeed table. Rotate the cutterhead slowly so the knife passes beneath the stick. If the stick doesn’t move, the knife is set too low. If the knife just brushes the stick, it’s flush with the outfeed table—which is still a hair too low. Ideally, you want the knife to drag the stick aout 1/8”, more than a 1/16” but less than 1/4”. This indicates the knife is a few thousandths proud, and your jointer will work just right, both now and as the knives wear toward dull. Move the setting stick to the near side of the outfeed table and make sure the knife drags the stick just the same amount to guarantee it’s parallel to the outfeed table across its width.
Repeat this process till all your blades are equal.
brianinpa
#11 posted 02-03-2011 05:13 AM
“I cant get that link to open. The page just stays on “loading”…..it’s been loading for 10 min!”
It appears that the Vintage web serve was down, but it is once again working.
View chet60's profile
chet60
3 posts in 228 days
#12 posted 06-06-2018 12:01 PM
Hey ,use a magnet,set on top of front table,overhang so the blades touch the magnet.
