Out Feed Table
Forum topic by prap posted 02-03-2011 08:19 AM 12690 views 2 times favorited 17 replies Add to Favorites Watch
View prap's profile
prap
50 posts in 2671 days
02-03-2011 08:19 AM
Topic tags/keywords: question
First of all let me start by saying I’m new to this site (although I’ve been lurking for awhile) and a rookie to woodworking. I must say you have a great site here, very informative and very friendly. You will probably get sick of all my questions I’ve got to ask, some might seem dumb, but where else does a 56 year old rookie woodworker got to go. Well my first question is, a couple of weeks ago I seen this video clip on this out feed table that double as a work bench that rolled over the table saw when you weren’t using it. It seemed like a good idea and not to difficult to make. Now I can’t find it, does this ring a bell to anybody? I don’t even have the table saw yet, hopefully by the spring, if I ever decide on which one. I was looking for reviews on table saws and thats how I found this site in the fist place,but thats an other topic for an other day.
Thanks in advance
Phil
17 replies so far
View crank49's profile
crank49
4030 posts in 2967 days
#1 posted 02-03-2011 12:25 PM
http://lumberjocks.com/projects/31507
This might be the project you are looking for.
I found this by using the “Search” feature; looking for: outfeed table workbench.
This result was the second link on the list.
View rieferman's profile
rieferman
39 posts in 2687 days
#2 posted 02-03-2011 09:05 PM
I’ve been very strict in teaching myself not to use the table saw outfeed as a work surface… because every time I do (and I mean EVERY time) I suddenly have an unforseen need to use the saw, and have to clear all my work.
My point is that although it seems like a great idea to make a swiss army solution but if you have space to make a dedicated outfeed, AND a dedicate workbench, that may be worth doing for convenience sake. Then again, what do I know? :)
-- New to woodworking, old to barn fixin'
View prap's profile
prap
#3 posted 02-04-2011 04:35 AM
crank49, Thats the one, Wood magazine site is where I must have seen it.
Thanks again
rieferman, I wouldn’t be using it as my primary bench. Its main use would be for an outfeed table that would not take up any extra room when not in use and maybe some extra bench top space if I needed it.
View pintodeluxe's profile
pintodeluxe
5654 posts in 2809 days
#4 posted 02-04-2011 05:05 AM
https://s3.amazonaws.com/vs-lumberjocks.com/lg2of0m.jpg
here is my version
View Sarit's profile
Sarit
549 posts in 3135 days
#5 posted 02-04-2011 11:16 AM
crank49, are you sure you didn’t get the plan from me?
That fold up caster mechanism looks a lot like something I designed.
No worries if you did or didn’t. I just thought it was funny.
I believe the wood magazine version pivots in the middle of the caster holding board.
View teejk's profile
teejk
1215 posts in 2680 days
#6 posted 02-05-2011 09:41 PM
I have to agree with rieferman. my mobile outfeed table somehow became ideal space for a mortiser on one side and miter saw on the other. it would have been easy enough to build a new one but then my wife decided she didn’t like a cheap computer desk she bought and gave me several pieces of 3/4” melamine. A few 2×2’s mounted to the back of the cast iron table, a few legs, two dado cuts into the melamine to line up with the miter guage slots and a 4” hole to grant access to the splitter/hold-down guide bracket later I had a very nice outfeed table.
My need for outfeed was solely driven by the lack of cast iron beyond the blade (safety first!). It is only about 30 inches deep but I find that is more than enough for most things and is small enough to navigate around. When I need more depth for longer cuts I go with a roller stand behind it.
View redryder's profile
redryder
2393 posts in 3097 days
#7 posted 02-06-2011 08:18 AM
About the first 20 years I owned my contractors table saw, I never heard of an out feed table. I thought you just cut the wood and winged it on the floor, walked around and picked it up. I started going through some internet sites and found that people had these out feed tables next to thier saw and you could slide the cut wood on to. I built one of these bad boys and ya it does do it’s time as a work table also. I just wish I would have gotten in the game sooner.
-- mike...............
View Sawkerf's profile
Sawkerf
1730 posts in 3064 days
#8 posted 02-06-2011 04:46 PM
As cool as it would be to have dedicated cutting and working surfaces, most shops don’t have the room and will need to get double (or triple) duty from whatever they have.
If you’re going to have a mobile table for use as an outfeed table, make sure that you either put the saw and table in exactly the same places every time, or you can easily adjust the height so it doesn’t interfere with a board coming off of your saw. It’s a real PITA to be cutting down a sheet of plywood and have the edge hit the outfeed table.
My saw and outfeed/work table are fixed, and I have the outfeed height set ~1/8” below the height of the saw table.
View HorizontalMike's profile
HorizontalMike
7755 posts in 2910 days
#9 posted 02-06-2011 06:30 PM
Ditto on what Sawkerf says. I am building my WW-bench to be 1/4” shorter than my TS. If this doesn’t work as well as I have planned then I will place 1/4” rubber horse stall pads under/around my bench (to catch dropped tools and foot/back relief) and maybe a single roller between as a transition between the two.
View FiatBen's profile
FiatBen
2 posts in 3125 days
#10 posted 02-06-2011 07:41 PM
to pintodeluxe
that is sweet!
gets me to thinking
-- hillbilly in the woods
View Richard's profile
Richard
1916 posts in 2686 days
#11 posted 02-07-2011 10:44 PM
Looks a lot like one that Norm did on New Yankee Workshop, it was copied from one found in the WGBH TV props making department.
View Jeremy Greiner's profile
Jeremy Greiner
568 posts in 2768 days
#12 posted 02-08-2011 05:04 PM
I agree with rieferman seperate tables make things a lot easier. If you’re starved for space I recomend using rockler’s outfeed table hardware kit (don’t buy the kit with the wood, just the hardware one). I made my outfeed table using that kit http://lumberjocks.com/projects/41857 I can remove it from the saw, fold up the legs and hang it flat against the wall.
I also made a stand alone work table that can be folded up and tucked away when you need the floor space for something else http://lumberjocks.com/projects/43562
-jeremy
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
View Mikeinsocal's profile
Mikeinsocal
1 post in 2626 days
#13 posted 03-15-2011 06:42 PM
HI< I am new here but want to jump in this thread. I have a 32” delta contracor’s saw, the kind with the motor hanging out the back. I added an extention table to the back of my saw the same depth as the motor past the table. The concept is the table saw foot print had to remian the same size, or pretty close. Attached to the extention is a folding out feed table that folds down from the back of the saw when I store it againist the wall, folds out when I use the saw or need an extra work bench. The entire table saw and out feed had the open legs removed and a storage box/dust collector box built underneath it on wheels so i can roll it any where in my shop. On the extention table (right side of the saw, I added a Bench dog lift with a PC 3 1/4 router, never come out of the lift. On the left side of the table saw I also added an folding extetnion to give me more suppport to the left of the blade. I will have out and working this weekend. I will post some pics whe I do, so you can rather than try to imagine from my humble description.
Just found this site an dlove it already. great way to share ideas and projects! Thanks for having me.
-- Turning good wood into sawdust!
View Don's profile
Don
12 posts in 2617 days
#14 posted 03-27-2011 06:35 AM
Hi Phil, I am also new to LumberJocks, and this will be my first real contribution to the forum!
To begin with Rieferman’s comment about not using the outfeed table as a work surface is sound advice – but hard to follow! I use a large sled on my saw, and have pushed stuff off the outfeed table (when folded down) because I didn’t see it sitting behind the sled. :( More to the point – build yourself an outfeed table – you will wonder why you waited so long to build one!
Here’s the one I made for my PowerMatic 64A contractors table saw. As you can see, the table folds down. My shop was fairly big when I made this table – the table was up all the time. It’s a good thing I made a folding table, as we have moved and my current shop is a small 2-car garage; the table is down most of the time!
Here’s a link to the Photo Album with 3 pages of photos; click the small photo to enlarge, and look at the caption for details.
enjoy…
-- Don
View prap's profile
prap
#15 posted 03-27-2011 04:03 PM
Welcome Don You sure did a nice job on that out feed table it looks store bought. If your outfeed table came out that good I’d like to se some of your other projects and I’m sure others would too. I just got an email yesterday saying that my table saw had been shipped so hopefully some time this week it will show up. Once I get it all set up on the mobile base and get the 220 in to my garage I’ll be able get going on the out feed table. I wasn’t expecting the table saw for an other month so I’m kind of behind on the planning stages.
Thanks for your input
Phil
