Power feeder suggestions and advice on Jointer
Forum topic by SweetTea posted 10-04-2017 11:33 AM 774 views 0 times favorited 4 replies Add to Favorites Watch
View SweetTea's profile
SweetTea
371 posts in 858 days
10-04-2017 11:33 AM
I am looking to get some suggestions and advice on mounting a power feeder to my Steelex ST1006 8” long bed jointer. The only function that it will have to perform is edge jointing 13/16” thick hardwoods such as maple and poplar. (and occasionally softwoods such as Alder)
I have been looking into buying the Grizzly Baby Feeder, which is only 1/8HP. Do you guys think that is enough horse power? I would think so being as it will only be edge jointing hardwoods less than 1” thick. Or should I step it up to the 1/4HP Grizzly feeder?
Have any of you guys ever setup a power feeder on a jointer? Is it difficult to setup correctly? Any advice or suggestions would be much appreciated. Thanks guys!
View toolie's profile
toolie
2148 posts in 2827 days
#1 posted 10-04-2017 05:07 PM
https://woodgears.ca/machinery/power_feeder.html
how much HP do you think this develops?
View Loren's profile
10477 posts in 3846 days
#2 posted 10-04-2017 05:12 PM
I think you may be asking for trouble. If you
are able to accurately straight-line rip the
edges before the jointer, fine, but putting
rough-edged lumber on a jointer with a
power feeder is not a recipe for success
I don’t think.
I have seen power feeders set up for surfacing
cuts on jointers. It’s also possible to set up
a feeder on a shaper or router table for
edge jointing. The advantage being that the
stock is flat instead of held on edge. Still,
I think it would need to be straight-lined to
within 1/16”-1/8” of dead straight before
feeding to whatever machine was setup
for jointing.
SweetTea
#3 posted 10-04-2017 10:12 PM
I don t think.
cuts on jointers. It s also possible to set up
for jointing.
- Loren
I never said that it was rough stock. The stock that I will be edge jointing has already been milled at the lumber supplier. I buy it already straight line ripped. The problem is that the stock rarely keeps a perfectly flat edge after it sets in my shop for a few days. It is close, maybe 1/16” or at most 1/8” off.
View jar944's profile
jar944
127 posts in 1636 days
#4 posted 10-08-2017 04:54 PM
I’d get a 1/2 hp. Mounting will depend on what jointer you have. Easier yet if you already have a shaper, just use a outboard fence to straighten your boards.
