Kitchen/Dining Table
Forum topic by Smirak posted 10-03-2017 04:30 PM 430 views 0 times favorited 4 replies Add to Favorites Watch
View Smirak's profile
Smirak
78 posts in 755 days
10-03-2017 04:30 PM
Quick question…
I have some s4s canary wood that the wife wants a table top out of. The canary wood is 3/4 milled. I want the table top to be 1.5” thick (or thereabouts). I don’t want to laminate the 3/4 canary wood to get the thickness. Is it ok to use ply as a substrate? I would “edgeband” with additional canary wood.
Thanks,
Kevin
View Dustin's profile
Dustin
611 posts in 977 days
#1 posted 10-03-2017 04:50 PM
I haven’t had any experience using ply as a substrate, but I’m working on a welcome desk currently and essentially wanted the same effect. I found a great method that’s worked out well in the link below. You basically build your top oversized, cut two or so inches off of each edge, then “fold” them under and miter the corners.
https://wunderwoods.wordpress.com/2013/09/17/how-to-make-a-thick-countertop-out-of-thin-wood/
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
View Loren's profile
10477 posts in 3885 days
#2 posted 10-03-2017 05:16 PM
Solid wood always moves. If you glue solid wood
to plywood without gaps or shiplaps to allow for
movement, it won’t turn out well. Edgebanding
end grain also will cause problems.
You can build a table top with frame and panel
techniques to allow long grain all around the
edge. If you did that you could get away with
putting a thicker edging around the table top.
The outside corners of the frame would be
mitered.
More info here: http://www.woodweb.com/knowledge_base/Mitered_Frame_and_Panel_Table_Tops.html
View DS's profile
DS
3045 posts in 2657 days
#3 posted 10-03-2017 06:40 PM
You can use a plywood sub top as long as you allow the solid wood top to move using an appropriate attachment method.
Edgebanding end grain is not a good idea, but using a solid build up on the edge to make it look thicker is good, just keep the grain direction the same.
View JADobson's profile
JADobson
1329 posts in 2348 days
#4 posted 10-03-2017 07:10 PM
You might want to take a look this article from FWW. Very similar to the technique linked in Dustin’s post above.
http://www.finewoodworking.com/2017/03/29/thick-tabletops-from-thin-stock
(You’ll need a membership to read it)
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
