Inexpensive 7" DC fittings?
Forum topic by bigblockyeti posted 10-02-2017 03:48 PM 653 views 0 times favorited 12 replies Add to Favorites Watch
View bigblockyeti's profile
bigblockyeti
5206 posts in 1841 days
10-02-2017 03:48 PM
Topic tags/keywords: question
After a quick cursory search on LJ (and Google) I’ve yet to find any inexpensive vendors of 7” DC fittings and pipe except for this one: http://www.blastgateco.com. even Amazon has the same part number for the 7” elbow but at several times the price, it isn’t worth it. If nothing else materializes I will eventually make my way up there but the crating and shipping add a hefty sum to what I was hoping to find locally, any other ideas in sheet metal?
12 replies so far
View Carl10's profile
Carl10
108 posts in 577 days
#1 posted 10-02-2017 04:13 PM
Not sure if you have checked out KenCraft https://www.kencraftcompany.com/product-category/dust-collector-fittings/ but they have nice heavy duty DC fittings for very good prices ($29 for 24 gauge 6” Y). They are also very nice to deal with on the phone.
Hope that helps. Let us know what you do.
Carl
View AZWoody's profile
AZWoody
1396 posts in 1344 days
#2 posted 10-02-2017 04:52 PM
There is a large increase going from 4” to 6” and then even larger increases on the larger sizes.
I believe Grizzly has some of the other sizes in metal fittings but for blast gates, it might be best to make your own for the sizes you need.
I know ClearVue makes a 6” one that I use as well as transitions that let you go from 6” to double 4” as well.
View Hermit's profile
Hermit
189 posts in 1445 days
#3 posted 10-02-2017 08:35 PM
I would check at a/c wholesalers in your area. Here, most will sell to the public. I bought all my metal duct and fittings at one of these places and was a lot cheaper then anywhere else I could find. They may not have 7 inch in Stock but they can get it probably pretty quick.
-- I'm like the farmer's duck. If it don't rain, I'll walk.
bigblockyeti
#4 posted 10-02-2017 08:54 PM
I’ve done a bit if digging (used to be an HVAC tinner) and I can still buy at a couple wholesalers but finding large radius 90° elbows is proving the most problematic. I also want at least 26ga spiral pipe and most suppliers only carry 30ga and want a hefty minimum order for anything heavier. I did find 7” nordfab steel flex hose reasonably priced on Amazon and if it’s 5’ long, that would make 2 elbows I need.
View AandCstyle's profile
AandCstyle
3152 posts in 2377 days
#5 posted 10-02-2017 09:53 PM
Hey, Big, I don’t know if this will help you or not, but I never use large radius elbows. I do use 2 45 degree elbows with a short connector between them. However, I use PVC where there aren’t any large radius elbows to be had, the economics might not work out with metal fittings.
-- Art
Hermit
#6 posted 10-02-2017 10:00 PM
I also used 2-45’s because they couldn’t get the 90’s in 26 ga
View shipwright's profile
shipwright
8070 posts in 2918 days
#7 posted 10-02-2017 11:24 PM
This might interest you. I saved a ton of money doing this.
http://lumberjocks.com/shipwright/blog/31966
bigblockyeti
#8 posted 10-03-2017 12:28 AM
Thanks Paul, I actually have that as one of my favorites. I am planning on running either 4” or 5” PVC after the first 7” run which will consist of two 7” elbow and between 8’ & 10’ of spiral pipe and a wye into the side of the pipe which I will fabricate. Beyond that initial run, everything will look very similar to what you’ve done.
shipwright
#9 posted 10-03-2017 04:04 AM
You’re welcome. Glad I could help.
View Sparks500's profile
Sparks500
197 posts in 451 days
#10 posted 10-03-2017 11:44 AM
I learned this from the Pentz web site. They were actually pretty easy, pvc primer and cement covered with urethane caulk.
-- A good day is any day that you're alive....
Sparks500
#11 posted 10-03-2017 12:06 PM
I used a pipe fitters cutting gauge to make the segments. a belt sander helps too.
bigblockyeti
#12 posted 10-03-2017 01:11 PM
Thanks Sparks, I may try that method, just need to see what sizes I can get a deal on CPVC.
