| Forum topic by jmp | posted 838 days ago | 609 views | 0 times favorited | 6 replies | ![]() |
838 days ago |
I really like the idea of making the cherry low bookcase (Woodsmith 155) but cant source the 3/4inch cherry veneered ply anywhere in the UK. 19 mm veneered MDF is the nearest i can get. Will using MDF risk the shelves sagging though? Jonathan |
#1 posted 838 days ago |
I think you’ll be alright. Looking at a quick picture of the shelves in question it looks like the shelves are about 36” wide on bottom, but the dividers on the upper shelves will actually support them in the middle, so at 18” I think you’ll be fine. What veneered ply can you source? Especially with a dark stain birch ply and cherry blend together easily, and if you want a lighter tone, you could just build the whole thing from birch and stain it a medium tone. |
#2 posted 837 days ago |
Hard to say. Mdf has its purposes, but I wouldn’t use it for shelving. I would tend to use an alternative wood rather that mdf if the cherry is unavailable simply because shelving tends to hold stuff that will eventually warp the mdf. Just my 2 cents worth… -- Power tools put us ahead of the monkeys |
#3 posted 837 days ago |
I dont know the width of the mdf, nor if its face framed or has a solid front edge (helps) but if its over 32” wide (even that, it’s “iffy”) it will sag -- "Good artists borrow, great artists steal”…..Picasso |
#4 posted 837 days ago |
That bookcase calls for a face frame. You can double up the mdf and it will never sag. -- He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you. |
#5 posted 837 days ago |
If forced to go with fiber board, you would be better served with HDF (high density fiberboard) as opposed to MDF (medium density fiberboard). Engineered wood flooring may also be an option. Go -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
#6 posted 837 days ago |
You could get a rough idea of the deflection by running the sagulator for different materials: |
| Forum | Topics |
Woodworking Skill Share
8787 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1527 |
3543 |
15758 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2836 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6152 |
