Sharpening lathe tools with a belt sander?
« back to Woodturning forum
Forum topic by landryj88 posted 10-02-2017 01:55 AM 2236 views 0 times favorited 8 replies Add to Favorites Watch
View landryj88's profile
landryj88
6 posts in 793 days
10-02-2017 01:55 AM
Topic tags/keywords: question jig shaping lathe
Hello,
So first off thanks for any advise in advance and also I know the first thing folks might want to say is get a slow speed grinder but there is no way that is happening right now.
So here is my question I have a porter cable belt sander and need to get some usable results while sharpening by turning tools. Does anyone have any advise?
Justin
8 replies so far
View MrUnix's profile
MrUnix
6346 posts in 2103 days
#1 posted 10-02-2017 02:02 AM
Belt sander works great… make or buy a jig so you can get repeatable grinds. You can buy them for lots of bucks, or make them dirt cheap like this one from scraps:
View bbasiaga's profile
bbasiaga
1118 posts in 1900 days
#2 posted 10-02-2017 02:17 AM
the biggest risk is that it will overheat and ruin the temper on your steel very quickly. So quick touch, quench in ice water, quick touch, ice water…etc….until sharp as you like it.
View TheDane's profile
TheDane
5366 posts in 3567 days
#3 posted 10-02-2017 02:43 AM
Check out Eddie Castelin’s video on Youtube … https://www.youtube.com/watch?v=aaqIGVmVHY8
View Wildwood's profile
Wildwood
2240 posts in 2039 days
#4 posted 10-02-2017 10:25 AM
I started out sharpening with same style belt sander, made a little wooden stand that could clamp to work bench which worked okay. Moved on to 6” 3450 RPM bench grinder & wolverine system, been using that set up for over twenty years.
Only tip have for you is use a light touch when sharpening your tools whether use belt sander or bench grinder.
Don’t need or want to quench HSS tools in water!
-- Bill
View loiblb's profile
loiblb
141 posts in 960 days
#5 posted 10-12-2017 03:46 AM
I have a attachment to use on one of my spare lathes for this
View Kelly's profile
Kelly
1918 posts in 2849 days
#6 posted 10-12-2017 04:11 AM
I have a few more toys now, but I started with a one inch Delta. It did a beautiful job and it was quick and reliable. My results were hit and miss. Fortunately, more hit than miss.
The ONLY reason I don’t use it as much is, I have a four wheel system with CBN wheels I can slow to a couple RPM’s, if I want. It’s still great for quick touch ups because it’s five steps closer to the lathes than the four wheeler.
If you overheat the metal, don’t quench it, if you’re using high speed steel [HSS], which is preferred for lathe work. Quenching is said to fracture the HHS. That said, the advice to use a light touch is good.
View TheFridge's profile (online now)
TheFridge
8874 posts in 1391 days
#7 posted 10-12-2017 12:51 PM
I like flat bevels. Use a disc sander myself.
Kelly
#8 posted 12-19-2017 09:48 PM
Now that I’ve turned a little and sharpened a lot, one rule I have is, my sharpener cannot, in any way, be tied to the lathe. That is for the same reason I don’t own a ShopSmith. More specifically, sharpening is, more often than not, a seconds operation. Having to spend minutes setting it up kills the joy.
I really like the looks of the one in the photo above, but I’d look at powering it some other way than the lathe.
Nowdays, I have a four wheel grinder with CBN and diamond wheels. The rig is driven by a commercial sewing machine motor, so I can vary the speed from zero to about twenty-four hundred RPM’s. Too, I can reverse the wheels. I also have a one inch belt sander and a buffing station. The CBN wheels have the Oneway sharpening jigs under them. In short, I’m covered on the sharpening end.
Even though I have the Oneway jig system with CBN wheels, I, very often, just turn around and touch up tips on the 1” belt sander. A seconds job.
When I need or want to change the profile of a knife, or if it’s been abused enough by my sharpening methods, then I’ll go to the jigs.
So, in the end, a belt sander (e.g., 3-1/2×21) should do just fine. I wouldn’t go more coarse than, say, 220.
