Compressor Tank - Repairable
Forum topic by Marleywoodie posted 10-01-2017 04:10 PM 812 views 0 times favorited 18 replies Add to Favorites Watch
View Marleywoodie's profile
Marleywoodie
19 posts in 516 days
10-01-2017 04:10 PM
Anybody know anything about compressor tanks? I got this as part of a bigger equipment purchase. The previous owner had (tried) to put some attachment on it so he could spray finishes with it. The threads are all buggered up as you can see from the picture.
Can this this be plugged up sufficiently so I can use the compressor, or is it just trashed. Is it worth trying to fix?
18 replies so far
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1249 posts in 1800 days
#1 posted 10-01-2017 04:22 PM
Drill out hole, tap new threads, put in plug with ptfe tape. Done.
-- "Do or Do not. There is no try." - Yoda
View MrUnix's profile
MrUnix
6848 posts in 2285 days
#2 posted 10-01-2017 05:36 PM
Can this this be plugged up sufficiently so I can use the compressor,...
If I’m not mistaken, that is where the regulator/pressure cut-off switch are installed (seen hanging with what looks like a coat hanger in the picture), probably using a 1/4 NPT pipe nipple. You can’t just plug it up. Since the nipple is a pipe thread, I’d try re-installing the existing 1/4” nipple with some teflon tape first. It might just have enough thread to fit. Otherwise, you will need to clean up the hole/threads, go up to a bigger nipple and use an adapter on the regulator end to reduce it back to it’s original size. Certainly fixable, and probably pretty easily.
View William Shelley's profile
William Shelley
576 posts in 1555 days
#3 posted 10-01-2017 05:40 PM
Harbor freight sells a cheap set of 1/4, 3/8, and 1/2” NPT taps. You could drill out the hole and tap the next size up. The only issue I see is that you’d end up with metal shavings inside your air tank.
Just from the picture, that hole does indeed look “buggered”. Doesn’t look to me like you could even get a pipe to thread into that mess at all.
-- Woodworking from an engineer's perspective
View Redoak49's profile
Redoak49
3403 posts in 2075 days
#4 posted 10-01-2017 05:53 PM
Those fixes might work or might blow at at high pressure and go ballistic. If it were me, I would not try it.
Marleywoodie
#5 posted 10-01-2017 10:11 PM
- Redoak49
And that is my fear.
What if I got it welded closed?
MrUnix
#6 posted 10-01-2017 10:28 PM
- Marleywoodie
And then what? Drill it out and re-tap? Otherwise, you have no place for the air to get to the regulator and pressure switch, which kind of defeats the purpose of having a compressor :)
William Shelley
#7 posted 10-01-2017 11:48 PM
- Marleywoodie
- MrUnix
Unless it’s an auxiliary tank. But most home shops don’t need one of those!
woodbutcherbynight
5491 posts in 2495 days
#8 posted 10-02-2017 12:10 AM
You can rethread the hole and if you really want to make sure the pipe stays have it welded. Use a short nipple and a threaded cap so if you decide to use that spot later you still can. For homeowner stuff this is sufficient and will hold. Had mine done with the drain not wanting to come out. Got it out but it made a mess. Tapped to larger size and had welded. Was in use for 14 years before compressor got replaced for bigger unit. Never leaked that I saw and showed no signs of fatigue.
View AZWoody's profile
AZWoody
1366 posts in 1310 days
#9 posted 10-02-2017 12:13 AM
- Redoak49
It’s on the part of the tank that is reinforced to be drilled and tapped for fittings. There’s not going to be an issue of weakening by doing any of the fixes recommended unless it was not welded right or there’s a crack in the plate which checking out can determine.
View TungOil's profile
TungOil
996 posts in 581 days
#10 posted 10-02-2017 12:20 AM
If that were my compressor I’d try to chase the threads with the proper size tap to see if they will clean up sufficiently before going larger. Only if that didn’t work would I go the next larger pipe tap them bush it down.
A trick that my pipe fitters use when drilling or tapping to keep the chips out of the system is to fill the flutes with a heavy grease. the grease catches most of the chips before they drop into the tank.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
William Shelley
#11 posted 10-02-2017 12:24 AM
Honestly, although I’m all for fixing your own stuff, pressure vessels are one thing that should NOT be welded on unless you really know what you’re doing. Drilling and tapping is fine, but the heat from welding can alter the properties of the surrounding metal in ways that require structural analysis. The area near the weld could become more brittle than the rest of the tank and that COULD lead to an explosion.
So anyone suggesting welding on a compressor tank – please don’t. Unless you have the correct equipment to anneal the vessel after welding, don’t weld on it.
View johnstoneb's profile
johnstoneb
2995 posts in 2259 days
#12 posted 10-02-2017 03:02 AM
Yes you can plug it up but then you have a 30 gallon bomb sitting in your garage. Plug that hole you have no way of regulating the pressure in the tank and no way of getting air out of the tank except when the tank reaches its pressure limits and blows up.
-- Bruce, Boise, ID
View pauljuilleret's profile
pauljuilleret
102 posts in 1739 days
#13 posted 10-02-2017 11:23 AM
when I look at the picture to me it looks like the pipe has broken off in the tank. If that is so try using an easy out and see if you can remove the broken pipe that way.
View PPK's profile
PPK
1095 posts in 896 days
#14 posted 10-05-2017 01:55 PM
Honestly, although I m all for fixing your own stuff, pressure vessels are one thing that should NOT be welded on unless you really know what you re doing. Drilling and tapping is fine, but the heat from welding can alter the properties of the surrounding metal in ways that require structural analysis. The area near the weld could become more brittle than the rest of the tank and that COULD lead to an explosion.
So anyone suggesting welding on a compressor tank – please don t. Unless you have the correct equipment to anneal the vessel after welding, don t weld on it.
- William Shelley
This man is right. For your own and other’s safety, please don’t try welding a pressure vessel. Tapping threads could work, most likely.
-- Pete
View PPK's profile
PPK
#15 posted 10-05-2017 02:01 PM
Is it worth it? Well, does the compressor run? Is it one of those oil-less ones? You can buy a brand spankin new oil-less one for about $150… (I personally don’t like the noisy oil-less compressors) So I guess that’s your call
-- Pete
