carbide tool question
« back to Woodturning forum
Forum topic by Karda posted 10-01-2017 02:13 AM 715 views 0 times favorited 11 replies Add to Favorites Watch
View Karda's profile
Karda
1222 posts in 669 days
10-01-2017 02:13 AM
I made a carbide tool with a round cutter, I was wondering what are the square and the square with a radius used for thanks
11 replies so far
View Woodknack's profile
Woodknack
12329 posts in 2495 days
#1 posted 10-01-2017 02:46 AM
Same as you would use a flat scraper. You can plunge or rough a blank, square off ends of a spindle, shear scrape.
Karda
#2 posted 10-01-2017 03:04 AM
ok thanks
View hairy's profile
hairy
2750 posts in 3648 days
#3 posted 10-01-2017 06:07 PM
I use a square cutter when making mortise and tenon joints, as in fitting the top into the bottom of a turned box.
Also for tenons to fit in a chuck. I don’t have any dovetail jaws, all serrated jaws.
-- My reality check bounced...
View LeeMills's profile
LeeMills
583 posts in 1417 days
#4 posted 10-02-2017 12:15 AM
I have only used my square for roughing a bowl blank. Working from the tailstock end to go into side grain rather than end grain; hopefully straight but no more than 45* before switching to a bowl gouge.
Harry’s use of fitting a box lid sounds good also.
Karda
#5 posted 10-02-2017 01:44 AM
OK THANKS, will be my next too. What is the difference between the square and square with radius
LeeMills
#6 posted 10-02-2017 04:52 PM
I only have the straight. For what Harry suggested (boxes) you would want a completely flat edge, same for the inside bottom corners if that is what you want. I would think the radius would be easier for sheer scraping and general hollowing since the “corner” is back a bit and less likely to grab.
Maybe someone else uses both.
Karda
#7 posted 10-02-2017 05:13 PM
ok thanks, what size should I use on a 3/8ths shaft, I am metric challenged
LeeMills
#8 posted 10-03-2017 01:45 AM
I would use 1/2” bar for the additional strength. You may have to grind the tip back slightly for clearance but that is no problem. 1” = 25.4mm so my cheat is 1/8” = 3mm, (1/2” = 12.5); close enough for woodworking in most cases. If you already have the 3/8 bar then maybe 9 or 10 mm, not sure of all the sizes they come; you can also use the 12 or 12.5 and already have a small clearance. A mm each side ain’t much. :)
Karda
#9 posted 10-03-2017 02:12 AM
I measured my round tool it is about 5/8ths I used calipers so it if accurate. I think it is 15MM but don’t trust my memory any more
View Madrona's profile
Madrona
112 posts in 1010 days
#10 posted 10-03-2017 05:25 PM
The radius is less aggressive than the square. That said, if I use one it’s usually the square.
-- Living In The Woods Of Beautiful Bonney Lake, Washington
Karda
#11 posted 10-03-2017 06:11 PM
ok thanks
