Has anyone applied Arm-R-Seal on top of Waterlox?
Forum topic by marc_rosen posted 10-01-2017 01:39 AM 3362 views 0 times favorited 6 replies Add to Favorites Watch
View marc_rosen's profile
marc_rosen
146 posts in 3379 days
10-01-2017 01:39 AM
Hey Gang,
Today I scratched my cherry dining room table top while being careless. It was finished 5 years ago using Waterlox. I’ve since been using Arm-R-Seal for the majority of my finishing and wanted to know if anyone here has applied A-R-S on top of Waterlox. Any chance I will see something undesirable?
All replies are welcome and thanks in advance. Marc
-- Windsurfing, Woodworking, Weaving, and Woodducks. "Most woodworkers are usually boring holes"
117328 posts in 3776 days
#1 posted 10-01-2017 02:38 AM
If in doubt use a coat of 1 lb cut of dewaxed shellac it makes any two finishes work together when put in between .
View TungOil's profile
TungOil
1058 posts in 693 days
#2 posted 10-01-2017 03:09 AM
why not just repair the Waterlox? One of the benefits of Waterlox is repairability. sand the scratch out with 320 and recoat.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Rich's profile
Rich
3874 posts in 788 days
#3 posted 10-01-2017 04:04 AM
- TungOil
+1
View CharlesNeil's profile
CharlesNeil
2457 posts in 4069 days
#4 posted 10-01-2017 12:37 PM
Compatibility wont be an issue, however ,Waterlox does yellow pretty bad, my concern is if you sand the scratch out and use Arm R Seal your going to see a color difference, . If it were me I would try dribbling some water lox into just the scratch to build it up. I am assuming here that the scratch isnt deep , but just a finish issue .
Once level then clean and light scuff the top and do a full coat of finish.
View jdmaher's profile
jdmaher
437 posts in 2778 days
#5 posted 10-01-2017 02:20 PM
Arm-R-Seal over shellac over Waterlox is pretty much my “standard” finish.
When I started doing this, I had a ton of Waterlox (or, at least a couple of gallons) because we’d used it on our floor. I was worried about compatibility, as well, and decided on a wash-coat of shellac (1 lb) before the Arm-R-Seal. It probably doesn’t matter, but it has become standard for me.
On wood that is ACTUALLY blotchy, I start with a very skimpy wash coat of shellac (about 0.5 lb). Then Waterlox, to pop the grain – which ALWAYS works. Then I use a 1 lb. shellac to tweak color (and seal, though I’m not convinced that’s necessary). Then the Arm-R-Seal.
HOWEVER, do what Charles said: fill the scratch with Waterlox before applying Arm-R-Seal (if desired). Waterlox definitely DOES yellow.
That is, I wouldn’t just fill the scratch with Arm-R-Seal, because that’s what I had on-hand.
Are you adding a coat of Arm-R-Seal to the whole piece to improve finish durability? I’m sure Arm-R-Seal will do that, but one scratch in 5 years doesn’t seem too bad.
-- Jim Maher, Illinois
View bobasaurus's profile
bobasaurus
3544 posts in 3383 days
#6 posted 10-01-2017 05:41 PM
I’ve used arm-r-seal directly over waterlox, no problems at all. In the future, I plan on just using straight arm-r-seal.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
