20A breaker but only 15A outlet?
Forum topic by LucasWoods posted 09-30-2017 07:55 PM 1107 views 0 times favorited 37 replies Add to Favorites Watch
View LucasWoods's profile
LucasWoods
445 posts in 1419 days
09-30-2017 07:55 PM
I live in military housing and the breaker says that all the outlets for the living room recepticals and more importantly my garage recepticals is on a 20 amp breaker.
But all my recepticals look like this
How do I get a 20amp plug to go into these recepticals? Do I need a plug converter?
-- Colorado Springs, CO - USAF
37 replies so far
View Desert_Woodworker's profile (online now)
Desert_Woodworker
1543 posts in 1301 days
#1 posted 09-30-2017 08:54 PM
Make sure that you have a 20amp breaker and 12 gage wire
-- Desert_Woodworker
LucasWoods
#2 posted 09-30-2017 09:00 PM
So when I pull the receptical off I need to look at the wire and ensure it is 12 guage. If it is then I can throw on a 20 amp receptical?
Desert_Woodworker
#3 posted 09-30-2017 09:16 PM
Yes- 12 ga is used for 20amp – 14ga for 15 amp. Make sure to look in the beaker box to make sure that you have a 20amp breaker. If so you are good to go…....
View nkawtg's profile
nkawtg
280 posts in 1337 days
#4 posted 09-30-2017 09:23 PM
I would check with housing maintenance before making any changes.
View TaySC's profile
TaySC
270 posts in 419 days
#5 posted 09-30-2017 09:55 PM
If you’re living in military housing I would strongly suggest not making changes without having them approved first.
View Marlow's profile
Marlow
176 posts in 2757 days
#6 posted 09-30-2017 10:00 PM
What device are you using that comes with a 20 amp 120 volt plug: I ask because these would be unusual to find in typical hobbyist tool kit?
Marlow
#7 posted 09-30-2017 10:03 PM
I will say that its perfectly ok to have 15 amp (garden variety) receptacles on a 20 amp circuit: its done for kitchen outlets all the time and meets the national elec. code specs. The only requirement is that it must be a multiple outlet branch circuit.
LucasWoods
#8 posted 09-30-2017 10:07 PM
I looked and I can’t really see what guage. It is a yellow cable though. Two yellow cables one going to each “plug”
Yellow is industry standard for 12 guage wire correct?
LucasWoods
#9 posted 09-30-2017 10:08 PM
My dust collector is 115-240 and I don’t have a 240 outlet. The 115 option for the motor pull 17.8 amps.
And I can change out outlets but adding on to the breaker panel I would need to get approval.
Marlow
#10 posted 09-30-2017 10:15 PM
Yes, sounds like you are good to go: yellow Romex is the 20 amp variety. With a 20 amp receptacle and your 20 amp plug, you should be all set.
LucasWoods
#11 posted 09-30-2017 10:26 PM
Good! Side question.
The paddle switch I bought for my TS is smaller length wise than the hole but good on the width.
Should I get a small piece of tin to make up that gap? Just drill a couple of small holes and bolt it to the TS cabinet then fix the paddle switch to the TS and the piece of tin plating
Marlow
#12 posted 09-30-2017 10:33 PM
If you are talking about a switch like this: it should fit a standard electrical box with no modifications: not sure why it wouldn’t?
LucasWoods
#13 posted 09-30-2017 10:36 PM
I am putting it on my table saw. Not in the electrical box. The motor will tie to the switch then from the switch to a 20am plug going to the outlet.
Unless I bought the wrong thing? This is supposed to be the switch to turn on my table saw.
Marlow
#14 posted 09-30-2017 10:41 PM
Understand: this type of switch is designed to be housed in a standard electrical box, which would then be attached to your saw: these devices are all designed to play together without modification. You can get a a single box at any hardware store for around a buck or so: I assume then that your table saw for some reason is missing its original switch?
LucasWoods
#15 posted 09-30-2017 10:43 PM
I wanted to put a better switch on it so I may have thrown the old one away I thought the paddle switch was meant to attach to my table saw. Where or what switch do I get to replace the one for the table saw?
showing 1 through 15 of 37 replies
