| Forum topic by Alongiron | posted 843 days ago | 788 views | 0 times favorited | 8 replies | ![]() |
843 days ago |
Simple Question…...... Any ideas on how to minimize snipe on your thinkness planer? -- Measure twice and cut once..... |
8 replies so far
#1 posted 843 days ago |
Not sure what planer you have but one thing I read in my manual is to make sure the wheel lock is tightened before planing. Well, I always tightened mine down on my old ridgid planer but noticed it didn’t feel really tight. I would get snipe on occasion, and then it got worse and worse. What I did was take the hand wheel off and re-indexed the lock lever and now it gets real tight and has pretty much eliminated snipe all together. Some times it does happen but it is far less dramatic. Another thing that can help is the infeed/outfeed tables. If you raise them just a bit, it might help as well. -- Childress Woodworks |
#2 posted 843 days ago |
My dewalt dw733 used to produce a snipe until I raised the outfeed table to be a little higher than the center table. I also made an auxiliary planer table (just a sheet of melamine with a cleat to keep it from being pulled through) and gave it a good waxing. That along with making sure your cutterhead lock is engaged should eliminate most if not all snipe. |
#3 posted 843 days ago |
You can also use two sided tape and add 1/4 inch thick sticks to the outside of the board to be planed. Just extend the sticks 3-4 inches beyond the end of the board. This works for my Grizzly every time. Should work on any planer. |
#4 posted 843 days ago |
I had a bit of snipe with my Dewalt 735 too, and I raised the in and outfeed tables a bit on the outside ends like Sarit said and that took care of it. -- Wayne - Plymouth MN |
#5 posted 843 days ago |
Adding long infeed and outfeed tables (or feel rollers) works for I’m not a fan of the lunchbox planers. I don’t think they’re built You can mitigate snipe a bit by feeding stock at an angle. An |
#6 posted 843 days ago |
I have a Ryobi AP1301, which is kind of famous for sniping due to lack of infeed / outfeed tables. If I lift up on th end of the board opposite of where it goes in, and then again where it comes out, so that the feed rollers don’t have a chance to bite in to unsupported wood, the snipe goes away… Also feeding at a slight angle helps… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#7 posted 843 days ago |
I got rid of most of my snipe by making sure I had an outfeed table too adequately support the stock as it comes out of the planer. On long boards, some little bit of snipe is almost unavoidable on most home shop planers. For that reason I cut my stock a little long and trim off the snipe. -- roninkokomo |
#8 posted 842 days ago |
Hold up when starting . and make sure the out feed table is a hair high. that is how I do it on my 12” & 15” grizzleys. works for me. -- Chuck, wiswood2 www.wisconsinwoodchuck.com |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3554 |
15803 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
