sanding help
Forum topic by dminnery posted 09-30-2017 02:33 AM 691 views 0 times favorited 17 replies Add to Favorites Watch
View dminnery's profile
dminnery
6 posts in 2537 days
09-30-2017 02:33 AM
Topic tags/keywords: sanding
Hi All,
I’m looking for some solutions to labor intensive hand sanding.
The pieces are small animal shapes (4” approx in 3/4” thick stock).
I cut them on a scroll saw, then use a 1/8” roundover bit in my router table. There is always a little bit of tear out or rough areas that need to be sanded by hand. That is the step I’m trying to address.
So far nothing is as effective as hand sanding, or labor intensive.
I’m thinking there must be something out there that looks similar to that bit but is essentially an abrasive.
Most abrasives like this that I’ve found have a large diameter, 4” and up.
I’ve tried sanding mops, flaps and crosses. Most are too aggressive or can’t get in the tight spots I need.
Any thoughts?
17 replies so far
View Loren's profile
10477 posts in 3849 days
#1 posted 09-30-2017 02:43 AM
What brand of router bit are you using?
I haven’t made a study of it but many woodworkers
have attested that premium bits tend to yield
cleaner cuts.
dminnery
#2 posted 09-30-2017 02:50 AM
After trying many different brands, I’ve had the best results with Freud.
These shapes are for kids, so the profile needs to be perfectly smooth, hence the sanding.
View bigblockyeti's profile
bigblockyeti
5285 posts in 1921 days
#3 posted 09-30-2017 02:53 AM
I know for half of forever Craftsman sold sanding belts for their 12” handsaw that was pretty narrow, 1/2” or less if I remember. A setup like that would allow the scrolled edges and to a lesser degree, the radii where the top meets the edge.
#4 posted 09-30-2017 03:10 AM
yeah. You might consider using wood filler
on the rough patches and sanding that
back. It might go faster.
dminnery
#5 posted 09-30-2017 03:14 AM
the handsaw kind of puts me back to sanding by hand which is what I want to avoid. Can’t use filler as it’s a toy, plus I’d still have to sand that again which puts me back to square one.
I’m even taking with a guy about a custom helical insert round over bit. I don’t really see that solving the problem because it’s still a blade and will cause tear out.
View AlaskaGuy's profile
AlaskaGuy
4787 posts in 2510 days
#6 posted 09-30-2017 03:21 AM
Deleted
View tomd's profile
tomd
2175 posts in 3971 days
#7 posted 09-30-2017 03:28 AM
How about a rotary tool and the small sanding discs and drums they offer.
-- Tom D
dminnery
#8 posted 09-30-2017 03:37 AM
I appreciate all the suggestions.
I have tried every available flap, disc, star sander, wheel, sanding sponge, etc.
I just found a manufacturer that makes an abrasive that would mimic the profile of the round over I use, but the diameter is 4”. Obviously much bigger than your standard router bit diameter.
Trying to get hand sanding results without the labor and time of handsanding. Thinking that this can’t be a new problem something must exist somewhere out there!
View Aj2's profile
Aj2
1877 posts in 1999 days
#9 posted 09-30-2017 03:48 AM
The tear out is the real problem find a way to cut your pieces with minimal hand work.
-- Aj
View TungOil's profile
TungOil
1059 posts in 696 days
#10 posted 09-30-2017 03:49 AM
What kind of wood? Can you switch to something less prone to tear out?
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
dminnery
#11 posted 09-30-2017 04:00 AM
I use hard maple, cherry and walnut. Changing is not really an option.
View Bobthewoodbutcher's profile
Bobthewoodbutcher
27 posts in 1310 days
#12 posted 09-30-2017 06:00 AM
Check out http://katools.com/guinevere-minature-finishers/
This is a tool used by many serious scrollsaw workers for rounding edges etc.
dminnery
#13 posted 09-30-2017 06:17 AM
I was looking at that machine, however I read some reviews that indicated it was not very durable.
I use my tools a lot so durability is a factor. On average I get about 10-14 months out of my DeWalt Scroll Saw before they break.
View wuddoc's profile
wuddoc
319 posts in 3919 days
#14 posted 09-30-2017 06:19 AM
Tumbling is a method to round and smooth edges of small parts. Different abrasive media and sizes need to be experimented with in order to determine if this system will work in your application. Following is some information on the internet.
http://thefinishedpart.kramerindustriesonline.com/2009/09/wood-tumbling.html
-- Wuddoc
AlaskaGuy
#15 posted 09-30-2017 07:21 AM
I might help if we could see a photo of a few of these item with the burn marks on them. Were all kind of shooting the dark with out them.
