Link Belts on a Drill Press - DO IT!
Forum topic by William Shelley posted 09-29-2017 10:04 PM 3092 views 0 times favorited 44 replies Add to Favorites Watch
View William Shelley's profile
William Shelley
572 posts in 1494 days
09-29-2017 10:04 PM
Hi all.
I bought this drill press on craigslist a few years ago and it’s worked relatively well for me:
It made some wierd grinding/squealing sounds at certain speeds. There was a small amount of runout but I attributed it to poor quality drill bits and never paid much attention other than that.
I recently replaced the 1/2” v-belts with link-belts from Harbor Freight (the Accu-Link brand, I believe):
WHAT AN UPGRADE! The drill press is much quieter both when idling and drilling, the runout is completely gone, and the grinding/squealing sound stopped. The belts are also easier to change around when I need to adjust the speed.
I can also tell that the link belts work better because after drilling almost constantly for 30 minutes, the link belts are barely warm, whereas the old v-belts would have been very hot to the touch.
-- Woodworking from an engineer's perspective
44 replies so far
View jonah's profile
jonah
1727 posts in 3323 days
#1 posted 09-30-2017 12:39 AM
I put link belts on everything that’ll take one. My DP, band saw, and my old table saw, and all worked great. If I ever get around to it, I’ll replace my Unisaw belts with link belts. They are fantastic.
View Woodknack's profile
Woodknack
11777 posts in 2405 days
#2 posted 09-30-2017 12:43 AM
My drill press is nearly identical and squeaks if I make the belt really tight. So I push the lever back and let go (as opposed to holding it taught while I tighten it down) which leaves a little slack in the belt and no squealing. But I did put a link belt on it and it’s smoother.
View AlaskaGuy's profile
AlaskaGuy
4205 posts in 2334 days
#3 posted 09-30-2017 01:15 AM
lol, you are about 20 years too late with that.
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#4 posted 09-30-2017 01:21 AM
Not a fan of link belts for a multitude of reasons… and they won’t find their way onto my DP or any of my other machines. I do have one on my PM45 that was there when purchased, but it’s getting ready to be replaced with a real belt very soon.
View Redoak49's profile
Redoak49
3283 posts in 2013 days
#5 posted 09-30-2017 01:52 AM
So why are link belt not desirable. (My drill press has no belts)
William Shelley
#6 posted 09-30-2017 02:23 AM
How would a replacement belt fix runout on a drill press or any other machine.
- Joey2
It might not have an effect on a well-made drill press. But on a cheap taiwanese import from 1985, there’s likely not enough mass or rigidity to prevent belt-caused vibrations from traveling down the quill. That’s my theory anyway.
AlaskaGuy
#7 posted 09-30-2017 02:41 AM
I have link belts on a lot of tool in my shop. They have never cause me a problem.
Not a fan of link belts for a multitude of reasons… and they won t find their way onto my DP or any of my other machines. I do have one on my PM45 that was there when purchased, but it s getting ready to be replaced with a real belt very soon.
- MrUnix
This statement really needs some elaboration. If you don’t give us the reasons how do we learn. Leaning sharing is what this is all about I thought. when I worked on a Military Base in maintenance they had rolls and rolls of link belts in different sizes.
View jbay's profile
jbay
2337 posts in 924 days
#8 posted 09-30-2017 03:00 AM
I have link belts on my wide belt machine.
Without them, I would be taking the whole machine apart to change regular belts.
They work just fine other than they do stretch, and I have to adjust the tension every so often.
MrUnix
#9 posted 09-30-2017 03:14 AM
- jbay
IMO, that is about the only appropriate place to use them, and it is quite frequently done exactly that way in industrial environments where changing belts involve a lot of disassembly.
As to reasons I don’t care for them -
Link belts will cause premature wear and eat many pulleys, particularly die-cast ones, will stretch, and in a lot of instances can inject vibration and noise rather than reduce it. I’ve never had a problem using quality belts, replacing them when needed, and if the particular application has a smallish sheave, a cogged belt works best. YMMV.
AlaskaGuy
#10 posted 09-30-2017 03:36 AM
- jbay
As to reasons I don t care for them -
Link belts will cause premature wear and eat many pulleys, particularly die-cast ones, will stretch, and in a lot of instances can inject vibration and noise rather than reduce it. I ve never had a problem using quality belts, replacing them when needed, and if the particular application has a smallish sheave, a cogged belt works best. YMMV.
- MrUnix
Thanks for responding. I’ve read enough of your post over time that I value you knowledge. My mileage does vary. Maybe I don’t run my machines enough but I have never worn out a pulley and have helped with vibration on on my drill press and older Delta belt/disk sander. After many years I did just the other day pull one link out of my drill press. The other reason I like them is I have a roll on hand. If I need one I don’t have to make a trip to town
View oldnovice's profile (online now)
oldnovice
6898 posts in 3392 days
#11 posted 09-30-2017 04:50 AM
I have link belts on my Craftsman TS!
The TS is from 1972 and the belts are vintage 1976.
At that time I also replaced the cast pulleys with turned pulleys!
Last winter’s maintenance pass showed no belt or pulley issues but a lot of left over sawdust!
I was surprised and impressed on the difference in vibration free operation and decrease in noise.
View splintergroup's profile
splintergroup
2075 posts in 1247 days
#12 posted 09-30-2017 02:41 PM
I have a set installed on my Unisaw. They did help with vibration on startup, but the big day-to-day change I noticed is when I’m changing saw blades. I can rotate the blade to align the arbor nuts for the wrenches and where I stop, the blade stays put. Before this change, the blade often would turn back on its own, probably from a degree of “set” in the three short original belts.
jonah
#13 posted 09-30-2017 05:56 PM
Do you happen to remember how many links you used to make one unisaw belt? I’ve not done the replacement yet out of laziness.
Woodknack
#14 posted 09-30-2017 07:47 PM
The only negative I’ve had from link belts are that the green ones from HF are too wide for my tablesaw pulleys and make a lot of noise. I need to order the red ones which are narrower and all should be well.
AlaskaGuy
#15 posted 09-30-2017 09:36 PM
The only negative I ve had from link belts are that the green ones from HF are too wide for my tablesaw pulleys and make a lot of noise. I need to order the red ones which are narrower and all should be well.
- Rick_M
All my tools with link belts I’m using 1/2 wide belts. That would be my drill press which I think is the same one pictured in this thread, my wide belts sander, a home built stationary edge sander, a Delta disk/belt sander and my 4 pulley Delta Rockwell 12-14 cabinet saw.
http://www.fennerdrives.com/powertwist-plus/
showing 1 through 15 of 44 replies
