Circle Jig help
Forum topic by Karda posted 09-29-2017 06:28 AM 878 views 0 times favorited 10 replies Add to Favorites Watch
View Karda's profile
Karda
1222 posts in 669 days
09-29-2017 06:28 AM
Hi. I made a circle jig the same way I have made them in the past but for some reason the saw blade binds in the kerf and will not cut. I will stop the saw. What am I doing wrong. here are a couple pics thanks mike
10 replies so far
View AlaskaGuy's profile
AlaskaGuy
4353 posts in 2424 days
#1 posted 09-29-2017 07:28 AM
In your picture it looks like the center of you pin/dowel is in line with the center of the blade. If I remember correctly the center of the pin is supposed to be in line with the front of the blade.
What size blade are you using and what size circle is that?
View HokieKen's profile
HokieKen
6152 posts in 1253 days
#2 posted 09-29-2017 11:33 AM
AlaskaGuy has a good point about the pin being inline with the cutting edge, not the blade center.
My first thought though is that the blade is too wide for the diameter you’re cutting.
-- Kenny, SW VA, Go Hokies!!!
View Davevand's profile
Davevand
63 posts in 951 days
#3 posted 09-29-2017 12:45 PM
View GR8HUNTER's profile (online now)
GR8HUNTER
4532 posts in 827 days
#4 posted 09-29-2017 01:33 PM
just pull your sled back 1/4 ” should work perfect :<))
Rick Dennington
6080 posts in 3309 days
#5 posted 09-29-2017 02:49 PM
Here’s one I made a couple of years ago…...It cuts perfect circles every time…. I use a 3/16”-1/4” blade….
-- " It's a rat race out there, and the rats are winning....!!"
View DrDirt's profile
DrDirt
4451 posts in 3857 days
#6 posted 09-29-2017 03:54 PM
Yep – Alaskaguy, and the pic from Rick is the answer.
You need the axis to be where teh cutting is happening, rather than the blade center… then the kerf will be open enough to let your piece spin.
Rick – - Looks like we have the same saw, but you added some extra dust collection. (Delta 28-475X)?
Karda
#7 posted 09-29-2017 04:03 PM
the oin is at 1’5 inches for a 3 ’ circle, I have had the same thing happen with much larger. I’ll realign and see what happens thanks Mike
AlaskaGuy
#8 posted 09-30-2017 12:21 AM
Bump I hope to here what happened.
woodbutcherbynight
5545 posts in 2524 days
#9 posted 09-30-2017 02:18 AM
I had the above mentioned issue with where to put the pin. Through experimentation with a temp piece I found the sweet spot then made my adjustable slide with the correct position for the pin. Here are more pictures. LINK
Karda
#10 posted 09-30-2017 03:05 AM
Hi, I fiddled with the pin- blade orientation that was the problem. once I find the best spot i am going to make a better jig thanks for all your help Mike
