Need help with woodworking project
Forum topic by MonkTX posted 09-28-2017 11:19 PM 432 views 0 times favorited 7 replies Add to Favorites Watch
View MonkTX's profile
MonkTX
2 posts in 361 days
09-28-2017 11:19 PM
Hello Everyone,
I want to make a crate like the ones pictured below and I was wondering if someone could point me in the right direction to duplicate or come close to making the recesses for the wing nuts.
The only way I can think of to do it is using a forstner bit in my drill press and then cutting the bevel with a router. Does that sound like a good way or am I missing some simpler way of doing it?
Thank you all,
Monte
7 replies so far
View jimbrown's profile
jimbrown
22 posts in 416 days
#1 posted 09-28-2017 11:31 PM
Monte;
Other than a custom bit the forstner approach seems good to me. The original was probably one of a million for the military and had a special bit, probably in a gang driven drill press.
-- JimBrown
18869 posts in 1977 days
#2 posted 09-28-2017 11:54 PM
Sounds about right to me.
View TaySC's profile
TaySC
270 posts in 454 days
#3 posted 09-29-2017 12:03 AM
The only downside I can see to using a forstner bit is that the hole walls will be straight down, whereas I believe the ones in the box are tapered. I have no clue how you could do that and to be honest, it may not be that noticeable anyway.
It almost looks like the taper from a countersink bit.
View Carloz's profile
Carloz
1147 posts in 712 days
#4 posted 09-29-2017 12:15 AM
MonkTX
2 posts in 361 days
#5 posted 09-29-2017 01:21 AM
- TaySC
That is what I was thinking about using a router for, to bevel the hole.
View JBrow's profile
JBrow
1366 posts in 1041 days
#6 posted 09-29-2017 01:44 AM
MonkTX,
I am not sure whether a notching router bit would work. It would depend on your specifications for the hole and the specifications of the notching bit and whether you are willing to spend $60. Here is what I have in mind (the last four router bits)…
https://www.kregtool.com/store/c40/beaded-face-frame-system/
View Woodknack's profile
Woodknack
12341 posts in 2501 days
#7 posted 09-29-2017 02:45 AM
For a bunch I would custom grind a forstner bit. For one, forstner and router bit.
