Glue up question.
Forum topic by kennedy posted 01-31-2011 08:03 PM 996 views 0 times favorited 1 reply Add to Favorites Watch
View kennedy's profile
16 posts in 2626 days
01-31-2011 08:03 PM
Topic tags/keywords: glue assembly
Ispired by the amazing chopping boards I’ve seen on LJ I thought I’d try my hand at a smaller scale project. The plan is to reproduce the pattern above (on the left) from purple heart, maple and padauk making a 15mm thick board from which I can cut some discs to make an earring holder. To give some idea of scale the padauk peices are 10mm square and the purple heart strips 38mm long. I’ve cut the most of the peices and squared all the edges. My questions is, do I try gluing it all up at once or do it in small sections which I can then glue together to make the full peice? My feeling is that trying to do it all would mean a lot of glue joints on such a small scale could be tricky.
I was going to use Titebond III as I do for most things, would this be best for this application?
All suggestions appreciated.
1 reply so far
View chuck125's profile
1 post in 2628 days
#1 posted 03-16-2011 05:10 PM
On projects where I have to glue as I assemble, I use a quick setting glue. I have found that ‘Tacky Glue’ is just that, a white glue that sets in a few seconds and holds great. The problem is that our woodworkers supply stores don’t seem to handle it. They want to sell us the ‘Super Glue’ types. The solution is that it is found in sewing supply stores and is manufactured by ‘Alene’s’.
