Replacing a Vacuum Electrical Plug
Forum topic by housewife posted 02-27-2008 11:23 PM 1303 views 0 times favorited 4 replies Add to Favorites Watch
View housewife's profile
housewife
2 posts in 3741 days
02-27-2008 11:23 PM
I just replaced the plug on my vacuum, and it works. The specs on the vacuum say 120 V, 7.5 Amps. The Quick-Connect Plug, 2 Wire, that I replaced it with says its for a 10A – 125V, do not use type TPT extra flexible cords; use only with 2-conductor #18 SPT-1 or #18 SPT-2 flat cord. My cord is not flat. My concern is possible overheating. Is the replacement plug I used acceptable? Thanks.
View GaryK's profile
GaryK
10262 posts in 3988 days
#1 posted 02-27-2008 11:27 PM
I would not worry about the cord overhearing, or a plug rated over what the vac draws.
housewife
#2 posted 02-27-2008 11:37 PM
Thank you.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3874 days
#3 posted 02-28-2008 12:14 AM
You don’t have to worry about overheating. But there is another possible issue …
I think the reason for the warnings is that the clamp on the plug is designed for a flat cord, and when it is tightened it may either pinch the round cord, or it may not hold the cord securely. If it pinches, it could damage the insulation around the wires causing a break or a short. If it doesn’t hold securely, the wires might be pulled off the contacts and either short or become exposed.
If I was using it, I’d leave it and keep an eye on it. If my wif… uh, I mean … if Marianne were using it, I’d change it to one rated for a round cord.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View Suz's profile
Suz
51 posts in 3756 days
#4 posted 02-28-2008 04:09 PM
Gary, have you ever felt how warm the “factory” cord is after you make a few hot laps around the house with the vacuum? I think the manufacturers put the minimum quality cord on their machines to keep the costs down. However, I’ve never heard of a fire being caused by a vacuum cleaner. <grin>
-- Jim
