Do caulk and laquer work together?
Forum topic by spooled posted 01-31-2011 06:41 PM 7039 views 0 times favorited 3 replies Add to Favorites Watch
View spooled's profile
spooled
27 posts in 3032 days
01-31-2011 06:41 PM
Topic tags/keywords: question finishing
Can I use acrylic latex caulk [dap Alex plus acrylic latex caulk plus silicone] to fill some cracks on a cabinet I am building before spraying with laquer? I already sprayed it with laquer undercoat and would like to fill in some small joints before spraying the laquer finish.
-- Charlie,Treasure coast
3 replies so far
View FirehouseWoodworking's profile
706 posts in 3269 days
#1 posted 01-31-2011 07:35 PM
I’m thinking that might not be such a good idea. I think you may have a problem because of the silicone.
I’m guessing that you are painting with lacquer, given your comment about already spraying an “undercoat” as opposed to “sanding sealer”.
In either case, I would suggest to take the time and just build a quick and dirty test piece. It would be worth the time to figure out on scrap rather than a ruined finish that has to be removed and redone.
Good luck. Cheers!
-- Dave; Lansing, Kansas
View levan's profile
levan
472 posts in 2976 days
#2 posted 01-31-2011 08:13 PM
I have always used lacquer finish, and anything with silicone it is not permited anywhere close to the shop. It just creates all kinds of contamination problems. You might want to try using color putty for very minor fills. It comes in several colors. I use the one in little jars and you can even mix two together to match stain. Most lumber yards carry it for nail holes in paneling.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
spooled
#3 posted 01-31-2011 09:57 PM
Thanks for the replys, maybe a good caulk without the silicone will work? I am aware of the wood fillers and puttys available , but there are times [like now] that I would like to be able to put a little caulk in a non stress or visible crack. I don’t want to see any joint cracks when the laquer job is finished. I was told by a fellow at my local woodworking supply store that he heard that acrylic caulk is compatable with laquer. Any help will be appreciated.
