Finish for countertop near high heat
Forum topic by MrSa posted 09-27-2017 06:47 PM 451 views 0 times favorited 4 replies Add to Favorites Watch
View MrSa's profile
MrSa
4 posts in 284 days
09-27-2017 06:47 PM
Im building a stove top for a camper, its going to have two smaller burners side by side, each burner sits a flat stainless surround thats about 9”x12” the burner itself is maybe 3” diameter. so with the stainless surround being flat, the heat travels horizontally pretty easy, and the surround itself gets pretty hot.
I did a test with the burner at full blast without a regulator and wood sticking above the stove edge (so the burner sat “in” the wood) and i was able to scorch it. but that was the worst conditions possible which will never happen with this setup. What i’m more worried about is prolonged heat with a big pan sitting on it, being directed sideways over the countertop, i could see it being enough to cause some finishes to maybe bubble up, and the wood in contact with the stove surround, which gets pretty hot, for reference I could hold my hand on the edge of the stove and I could hold it there, but if i held it for like 10 seconds or more it would really start to hurt.
Anyway, I’m trying to find a finish and/or ideas that will hold up to the heat. I found this stuff http://www.countertopepoxy.com/premium-clear-epoxy-for-countertops-bar-tops/
says its resistant up to 500 degrees, which is probably plenty. but I dont want the shiny thick bar top look. I’d like to keep it thinner and a little more matte/satin.
any ideas?
View Woodknack's profile
Woodknack
11601 posts in 2374 days
#1 posted 09-27-2017 11:35 PM
A 3” diameter burner? That’s dinky.
I would put some fireproof barrier between the stove and wood. There are products that retard flame on wood but I wouldn’t depend on that or epoxy over the long term. There is such a thing as low temp spontaneous combustion that happens when wood is exposed to high temperatures (but not high enough to char or combust) over long periods of time.
View TheFridge's profile
TheFridge
9444 posts in 1480 days
#2 posted 09-27-2017 11:41 PM
That is true as I have spontaneously combusted when I spent too much time in the sun because I am a pale ginger.
View Andybb's profile
Andybb
964 posts in 597 days
#3 posted 09-28-2017 12:03 AM
I redid my kitchen counters with reclaimed blackboard slate. You can put a frying pan directly from the stove onto it. Then you’d never have to worry, and they look great. Just epoxy onto 1/2 or 3/4 plywood.
-- Andy - Seattle USA
View Rich's profile
Rich
2797 posts in 583 days
#4 posted 09-28-2017 02:04 AM
I’d go with engine block orange hi-temp paint.
Seriously though, I’d go with Rick’s suggestion of placing some heat barrier around it. That burner might seem small at 3”, but the flame shoots horizontally and with a pan on it all of the heat will radiate outwards. Any unprotected wood will be damaged.
-- No matter how much you push the envelope, it'll still be stationery.
