Dovetail practice wood
Forum topic by tas121790 posted 01-31-2011 02:06 AM 2403 views 0 times favorited 9 replies Add to Favorites Watch
View tas121790's profile
tas121790
4 posts in 2832 days
01-31-2011 02:06 AM
Topic tags/keywords: dovetail wood type
I took a woodworking class at a community college and the only wood we had to use for dovetails was warped construction pine from menards. It would frequently split and break and i was wonder if there was a better wood to use for practice that was reasonably priced whether it was hardwood or another variety/grade of pine doesn’t matter. I also understand that the first time making dovetails isnt going to turn out well, i just want a medium that allows good results and allows skill improvement.
9 replies so far
View barryvabeach's profile
barryvabeach
159 posts in 3069 days
#1 posted 01-31-2011 03:24 AM
+1 on Poplar. Pine is just too soft and crumbles easily, poplar is a dream in comparison.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3184 days
#2 posted 01-31-2011 04:22 AM
+2 on Poplar.
-- jay, www.allaboutastro.com
View dbhost's profile
dbhost
5726 posts in 3258 days
#3 posted 01-31-2011 04:26 AM
Poplar again… Pine is a BAD lumber to use for dovetails. I have tried, repeatedly, without success, to cut clean dovetails in pine. It blows out worse than cutting DTs in plywood….
View wseand's profile
wseand
2796 posts in 3067 days
#4 posted 01-31-2011 04:47 AM
I would go down to your local lumberyard and see if they have some PC Maple, I get it for 1.40 a BF. If you have a lumber yard near you go check it out and see what they have.
View Lumber2Sawdust's profile
Lumber2Sawdust
139 posts in 2891 days
#5 posted 01-31-2011 06:30 AM
I was in a class with Rob Cosman in December. He actually makes everyone start cutting dovetails with pine when he teaches a dovetail class. The biggest reason he does that is because pine is soft and will show your mistakes (if you are practicing, you WANT to see mistakes). One of the bad habits people develop is to lever the chisel against the board when chopping out waste. The result is rounding over the edges of the join, making it look sloppy. Similarly, if you are blowing out the board when chopping dovetails your technique needs some work.
If you have the tools to do it, make sure your boards are flat, wherever you get them from.
Poplar would be a good second choice, but I would recommend whichever is cheaper.
good luck
TopamaxSurvivor
18290 posts in 3701 days
#6 posted 01-31-2011 06:50 AM
The pine should not have been quite that bad. It must have been salvaged from beatles or fire??
tas121790
#7 posted 01-31-2011 07:05 AM
“Similarly, if you are blowing out the board when chopping dovetails your technique needs some work.”
This certainly doesn’t surprise me, we spent all of 4 hours learning about dovetails, never once learned about proper chisel technique (or sawing for that matter). Half way thought the semester i concluded that im going to have to just sart reading up and teaching my self.
Thanks for the replies.
TopamaxSurvivor
#8 posted 01-31-2011 07:11 AM
That is a good point. A dull chisel will blow pine to smitherines.
