Double sided tape
« back to Coffee Lounge forum
Forum topic by Hornnumb2 posted 09-25-2017 02:43 PM 883 views 0 times favorited 6 replies Add to Favorites Watch
View Hornnumb2's profile
Hornnumb2
38 posts in 1032 days
09-25-2017 02:43 PM
I keep seeing people use double sided tape, but the only tape I have seen is the 3m foam type. Can somebody link what I need to get. Thanks Michael
View JRsgarage's profile
JRsgarage
309 posts in 712 days
#1 posted 09-25-2017 02:50 PM
lot of places sells them but here is one from woodcraft…..https://www.woodcraft.com/products/double-sided-tape-1-x-36-yards?gclid=EAIaIQobChMIlr_Z9cnA1gIV04WzCh29EQMQEAQYASABEgIu1_D_BwE
-- Two is One, One is None
View DrDirt's profile
DrDirt
4511 posts in 3945 days
#2 posted 09-25-2017 02:53 PM
I use 2 versions.
First type I use for template work, or to lock two pieces together to cut at teh same time and for holding a zero clearance fence on the miter saw….
That is a cloth backed ‘carpet tape’. I prefer cloth backed because (1) like the foam tape, it comforms to irregular surfaces and gets a better grip. 10 bucks a roll
https://www.amazon.com/Double-Coated-Sided-Carpet-Installation/dp/B01FWQD95Y/ref=sr_1_2_sspa?ie=UTF8&qid=1506350830&sr=8-2-spons&keywords=cloth+double+sided+tape&psc=1
Second type is for simple stuff, where I don’t want a lot of added thickness. Sometimes I use this to hold thin ‘
veneers’ to a backer board, where the thick carpet tape would give me a weird ‘depression’ in the wood. or I just want a piece not to slide around, like sticking a sheet of sandpaper to the wing of the tablesaw.
I only use the foam tape for putting up signs on the wall.
View Rich's profile
Rich
3887 posts in 793 days
#3 posted 09-25-2017 07:00 PM
Golf club grip tape is the same thing the wood stores sell and is about half the price. It’s good for about 90% of my needs, like attaching jigs and templates to boards. Double-sided carpet tape is much stronger if you need something attached more rigidly.
View oldwood's profile
oldwood
155 posts in 1447 days
#4 posted 09-26-2017 02:51 AM
Carpet tape, thin but strong. Any hardware or big box store. Go with a name brand.
MrUnix
7051 posts in 2402 days
#5 posted 09-26-2017 03:20 AM
- oldwood
Yup… sometimes TOO strong :)
View ArtMann's profile
ArtMann
1156 posts in 1019 days
#6 posted 09-26-2017 01:10 PM
Carpet tape forms quite a strong bond and should be used judiciously. I sometimes use it to attach material to the spoil board of my CNC router before cutting or engraving and it does a good job (almost too good).
