craftsman saw question
Forum topic by jaydad17 posted 01-30-2011 01:04 AM 1212 views 0 times favorited 9 replies Add to Favorites Watch
View jaydad17's profile
jaydad17
17 posts in 3281 days
01-30-2011 01:04 AM
Topic tags/keywords: craftsman saw belt blade
Hello all! I have a question i was hoping someone out there had an answer to. I have a 1988 model craftsman contractor saw and everytime i adjust the blade height the belt either loosens or tightens depending on which way I am moving the arbor. This is more of an annoyance than anything else but i was wondering if any one else got tired of adjust the motor height like i am. Thank you
-- Jay NE Tennessee
9 replies so far
View Paul Pomerleau's profile
Paul Pomerleau
309 posts in 2601 days
#1 posted 01-30-2011 01:40 AM
On my Craftsman TS approx the same age, the motor is hanging out the back and pivots on a rod at the bottom of the plate. The top of the plate is a bolt (1/4×20 silver in my pic) that should not be too tight as to restrict the movement of the motor, it should only keep the motor lined up with the pulley for the arbor.
Maybe that screw is too tight and not allowing the motor to pivot.
I took a picture of mine to show you what I mean.
I took the belt cover off so you can see it better.
Hope this helps.
-- Close to Ottawa Ontario Canada
View brianinpa's profile
brianinpa
1812 posts in 3631 days
#2 posted 02-03-2011 03:23 AM
You know Charlie you could have imparted a little wisdom from your 30 years of experience and helped out with this guys question, but that’s right “There isn’t any benefit in it for you.”
Jay,
The belt is tensioned by the weight of the motor hanging against the belt and arbor. The bolt that you are constantly loosening/tightening as you raise/lower the blade is too tight. Just tighten it slightly to reduce vibration and the motor will raise/lower with the blade. I only tighten my motor in place if I am going to be using the saw at the same setting for long period of time.
Good luck and remember that lumberjocks is a place to share :)
jaydad17
#3 posted 02-04-2011 11:49 PM
Thank you all for your advice and for charlie I bought the saw second hand and did not get a owner’s manual. I am a maintenance mechanic by trade so the thought of leaving the bolt loose never occurred to me. I did not really like the idea of just leaving it loose so I came up with an alternative. I got a longer bolt from my stash and also came up with a compression spring. I tightened enough so the the motor will pivot but the spring holds it tight enough that it will not vibrate i attached a couple of pics. Thank you again.
-- Jay NE Tennessee
View teejk's profile
teejk
1215 posts in 2592 days
#4 posted 02-05-2011 01:48 AM
you should not need the spring…if designed properly the weight of the motor should give you the needed tension. if not, a little oil at the arbor end or time for a new belt (they stretch with time and temp).
brianinpa
#5 posted 02-05-2011 03:59 AM
Wjat model saw do you have Jay?
View William's profile
William
9949 posts in 2750 days
#6 posted 02-05-2011 05:28 AM
I have a Rigid 3650. I had to add a spring to mine too. The bolt kept backing out. I guess it was from the slight vibrations of the saw, I don’t know. Anyway, I added a spring like you did just to keep tension on the bolt. It keeps it from backing out. The motor can rise and lower itself like it was intended to do. It’s been on there for months now and I haven’t had anymore problems.
jaydad17
#7 posted 02-05-2011 04:45 PM
brianinpa I have a 113.298721. like i said I bought the saw second hand and added a custom on of switch with a dead man stop switch mounted on the left leg of the saw.
-- Jay NE Tennessee
brianinpa
#8 posted 02-05-2011 05:03 PM
Not sure if you found an owners manual yet, but here is a link one that should be similar.
View IrreverentJack's profile
IrreverentJack
727 posts in 2751 days
#9 posted 02-05-2011 06:22 PM
Jay I like the spring idea. I put a nylon washer there already, but a spring (sort of like the trunnion lock) might keep it from vibrating a little. Here is the link for the manual Brian wanted to give you. Good luck. -Jack
