DeWalt 735 Tripping Breaker Panel (only after i turn it off)
Forum topic by BoilerUp21 posted 09-25-2017 01:40 AM 675 views 0 times favorited 3 replies Add to Favorites Watch
View BoilerUp21's profile
BoilerUp21
85 posts in 789 days
09-25-2017 01:40 AM
I just got my DW735 and have only used it to test out and adjust tables to minimize snipe. It works fine with no issues….until i turn it off. about 1 second after i press the stop button, the breaker (main panel in my basement) trips.
Wondering why it would do this when shutting off and not turning on (as i assume it draws more amps to turn on)?
3 replies so far
View JRsgarage's profile
JRsgarage
247 posts in 532 days
#1 posted 09-25-2017 03:24 PM
possibly a loose wiring in the switch/outlet causing a short. have you tried on a different outlet?
-- Two is One, One is None
View Carloz's profile
Carloz
1147 posts in 614 days
#2 posted 09-26-2017 08:04 PM
Take an ohmmeter, unplug the planer and connect the leads to the prongs of the planer. Turn it on an off. When it is off the resistance should immediately drop to infinity.
Repeat the same with the ground and the hot prong. ( it is on the left when looking from the prongs side) and do the same.
If the circuit does not open when switching off you have a problem with the planer.
View splintergroup's profile
splintergroup
2071 posts in 1245 days
#3 posted 09-27-2017 05:39 PM
Is your breaker a GFCI breaker?
These can trip from the back EMF spike when you turn a motor off. I had a ceiling fan that would constantly trip a GFCI breaker when turned off.
