How can I learn hoow to glue up a Sinister Type cutting Board without paying Photobucket?
Forum topic by newwoodbutcher posted 09-24-2017 07:05 PM 5178 views 0 times favorited 13 replies Add to Favorites Watch
View newwoodbutcher's profile
newwoodbutcher
781 posts in 3089 days
09-24-2017 07:05 PM
I don’t need Photobucket (except for this one time use) . I have the patterns and have made all the parts for a Sinister Type Cutting Board. And now it’s glue up time. I can’t see anywhere how see/learn to accomplish this step without buying a subscription to Photobucket. Here’s a picture of the jig/sled I made a with fixed stops at 90 degrees on a piece of mdf.
Trying to get everything lined up and all the gaps closed for a dry clamping test is proving to be….. difficult. Every place I’ve been on the net wants me to have photobucket (Including here) to learn this next step. Advice? Pictures?
-- Ken
13 replies so far
View diverlloyd's profile
diverlloyd
3288 posts in 2096 days
#1 posted 09-24-2017 07:41 PM
I glue mine up with the points touching a 90 degree jig that is screwed down. Then use a flat piece on the other side and front to clamp to. If I had to do it over I would come up with a better way then individual pieces. If you need pics I can go out and take a pic of the jig but the cutting board is already done and squared. I should post it as a project maybe. I also glue up on a piece of tempered glass. Check to make sure all the pieces are the same a couple of mine were of by .05 and I made some more cuts to get them all with in .01 and it made a difference.
View Aj2's profile
Aj2
1952 posts in 2037 days
#2 posted 09-24-2017 08:22 PM
Ken that project is a mess to me it looks impossible to glue without gaps.
-- Aj
newwoodbutcher
#3 posted 09-24-2017 08:23 PM
Hey Diverlloyd, Thanks for responding. Points touching the jig!!! That’s the solution! Sounds like your “jig” and mine are the same basic idea but I was aligning the pieces on their flat edges not the points. I’ve just come back from following your advice and it works a whole lot better. Thank you. What glue did you use? I’m thinking something with a long set up time but still water resistant.
-- Ken
newwoodbutcher
#4 posted 09-24-2017 08:27 PM
Aj2. I agree, I’m thinking CA glue will be my best friend. I’ll post the finished project as long as it doesn’t get converted to firewood first.
-- Ken
View papadan's profile
papadan
3584 posts in 3607 days
#5 posted 09-24-2017 09:43 PM
I’m curious, what would Photobucket have to do with making a cutting board?
View RRBOU's profile
RRBOU
176 posts in 2531 days
#6 posted 09-24-2017 10:38 PM
I m curious, what would Photobucket have to do with making a cutting board?
- papadan
Sinister has a great tutorial that now the photos are blocked.
-- If guns cause crime all of mine are defective Randy
newwoodbutcher
#7 posted 09-24-2017 10:43 PM
Papadan, The cutting board in question is intricate laminations cut into interlocking pattern designed (I think) by a Lumberjocks member. The member, Sinister, and a few other members have generously demonstrated the techniques for cutting the parts and the glue up. However, all their photographs have been hijacked by Photobucket. When you try to view the demonstrations the photographs are blocked with a message which links you to Photobucked who wants a $30.00 one year subscription to see them. I didn’t think I needed the photograps untill I got to glue up time, I was wrong, but Diverlloyd helped me understand how to better utilize the ” glue up jig”. This is a great site.
-- Ken
woodbutcherbynight
5832 posts in 2648 days
#8 posted 09-25-2017 01:07 AM
Try your local library. A neighbors kid informed me they had that available at ours. Not that I have been lately…. LOL
View PCDub's profile
PCDub
98 posts in 483 days
#9 posted 09-25-2017 01:56 AM
There is a chrome extension out there called “Photobucket embed fix” and through some trickery, it sees a photobucket embed link and changes the referrer. Long story short, some of the pictures appear.
So, using the Chrome browser (free from google.com), look under settings and find extensions, and search for the Photobucket embed fix extension. Install it, and you may be able to see the photos!
diverlloyd
#10 posted 09-25-2017 12:56 PM
I use titebond 3 and mine was 90pcs so i glued it up all at once. I work pretty fast though so don’t do more at once then you think you can get done. It would be a waste to get half way and have the glue set up before clamping.
View John_H's profile
John_H
190 posts in 1945 days
#11 posted 10-02-2017 11:06 PM
The chrome extension really does work – here is the link
https://chrome.google.com/webstore/detail/photobucket-embed-fix/naolkcpnnlofnnghnmfegnfnflicjjgj?hl=en
Example – here is thread (I am not sure if this is one of the ones you wanted to view}
sinister type cutting board tutorial #1: THANK YOU SINISTER , WHAT NICE BOARDS !
http://lumberjocks.com/patron/blog/15074
If I look at in Firefox – this is what I get
If I look at the same thread in chrome with the extension – I see this: (there is at least 14 pics on that one page)
newwoodbutcher
#12 posted 10-07-2017 03:53 AM
Ok, it wasn’t a pretty glue up, but CA glue saved the day.
Next time more precision and consistency making the “rods” thank you all for your help
It’s all cherry and hickory
-- Ken
View LittleBlackDuck's profile
LittleBlackDuck
2120 posts in 1060 days
#13 posted 06-22-2018 01:07 AM
- PCDub
Hi PCD, There is nothing better than to “out crook’ a crook. I for one appreciate the heads-up, however, I fear that this may only be a temporary work around.
Usually, when one finds a crack, “shady tradies” (and I tar PhotoBucket with the same brush) will paint over it and charge double. Unfortunately this fix will only encourage people to continue using PhotoBucket and when they develop a block (and at $500 per customer I’m sure they’ll be anxious if/when they discover this work around), by then they will have move victims they could potentially blackmail.
What we all should do is set up dummy posts and with the fix an inundate their (PB’s) traffic with overloads as retribution… Problem is, that would affect the innocent users that were blackmailed into an unwanted license.
I personally think that a company like PB, that attempts to blackmail their clients, is not worth pissing on and I would begrudge them any further waste of my precious time…
PS. Just a word of caution. Be aware that if you use the fix, PB have your details and with their money grabbing attitude be prepared to face repercussions… The fact that Google supplied the fix would not make me feel overly comfortable about their (Google’s) unquestionable support under potential adversity.
PPS.” Sorry new’butcher*, for the digression form you great work.
As an aside, at least here at LJ, you can upload your pictures direct without going through a middleman. For other sites and personal use, you can then reference/link your LJ site and screw PB up their chocolate-starfish. Only downside is that your picture posts are reduced in size.
