resurfacing cutting boards
Forum topic by Scott Gilroy posted 01-29-2011 10:30 PM 1862 views 0 times favorited 5 replies Add to Favorites Watch
View Scott Gilroy's profile
Scott Gilroy
45 posts in 2970 days
01-29-2011 10:30 PM
I mad a few end grain cutting boards for Christmas this year. The came out looking pretty good, but have noticed that the different species have changed due to environmental conditions at different rates, i.e. one species stands proud of the other. I don’t have a drum sander (YET), so I originally surfaced the boards using belt sander and ROS. Seemed to work pretty good. Now I notice the thickness variations in the different species. I may not have let all the woods acclimate long enough in the shop prior to producing the boards, so that could be part of the problem, or is it just due to the different species and their various shrinkage rates?
So, my main question is: should I just resurface them again or will the unevenmess reappear quickly again? or should I wait even longer to let the woods acclimate to their new homes and then resurface? Boards are refinished with mineral oil and wood combinations are: END GRAINS= MAPLE & PURPLEHEART, PADAUK & PH, FACE AND OR ENGE GRAIN = KOA & GABOON EBONY, CURLY MAPLE, PADAUK, WALNUT & CHERRY
Thanks in advance for the help (and thanks to all you boarders out their for the inspiration!!)
-- Scott
5 replies so far
View robert triplett's profile
robert triplett
1566 posts in 3073 days
#1 posted 01-30-2011 02:32 AM
I have had issues with ‘glue creap’ when I hurry to finish a board. The wood is ok, but the glue line is raised. I tried re-sanding, but someone suggested a card scraper and that has worked well. I have not had a problem with the boards themselves, except one Chevron board has warped when it went from our dry, desert summer to the wet coast in Eureka, CA.
-- Robert, so much inspiration here, and now time to work!!!
Scott Gilroy
#2 posted 01-30-2011 05:20 AM
Robert,
I don’t think it’s glue creep. One species is definitely thicker than the other. It’s the same on top and bottom. Maybe I’ll give the card scraper a try.
Thanks
-- Scott
TopamaxSurvivor
18249 posts in 3644 days
#3 posted 01-30-2011 11:27 AM
See what degoose has to say, he is the master board man on here.
View Tim Dahn's profile
Tim Dahn
1567 posts in 3534 days
#4 posted 01-30-2011 01:13 PM
After surfacing the cutting board, I will hold it under running water getting it completely wet, this will raise the grain almost immediately. After letting the board dry for several hours, I resurface the board. I do this usually a couple of times, when the grain longer raises I do a final sand and apply mineral oil.
View snowdog's profile
snowdog
1164 posts in 3951 days
#5 posted 01-30-2011 02:52 PM
I also have has the glue creep raise it’s ugly head but that ROS beat it back fast.
