Miter Bench Design
Forum topic by vetsin posted 09-24-2017 12:07 AM 393 views 0 times favorited 1 reply Add to Favorites Watch
View vetsin's profile
4 posts in 185 days
09-24-2017 12:07 AM
Hi all,
I’m looking for some input before I go and make myself a miter workbench. I plan on throwing a miter saw in the center and a RAS on the right side of the bench. Some questions/concerns of mine:
  • Any better way to join my vertical 2×4 posts to my lateral 2×4’s at the top? I was thinking just 3” screw’s would do the trick.
  • I plan on storing wood under this, do you think I can use wood (say doug fir) cross-bars or will I need metal? (Sized at 1.5×1.5”)
  • Should I worry about ensuring the three seperate benches can have a positive connection? My assumption is they will weigh enough that I won’t need to care.
1 reply so far
View Loren's profile
10101 posts in 3582 days
#1 posted 09-24-2017 12:43 AM
It looks plenty sturdy to me. You’ll need to
level the feet to bring the tables in plane
with your miter saw. In order for the fences
to be accurate I think it would be prudent
to screw it all together.
