Help with "stuck" clamp
Forum topic by BB1 posted 09-23-2017 04:36 PM 765 views 0 times favorited 17 replies Add to Favorites Watch
View BB1's profile
BB1
1151 posts in 870 days
09-23-2017 04:36 PM
I am not sure what I did but I am unable to get this Bessy clamp opened up. When I tried to adjust, the handle actually separated from the unit. I can put the handle back in place but still not able to manipulate the clamp in order to open the jaws. Feeling stupid that I cannot figure this out. Turning once again to the LJ…any suggestions would be very welcome
17 replies so far
View BB1's profile
BB1
#1 posted 09-23-2017 04:44 PM
One other question…any suggestions on the best way to remove old glue drips from clamps (other than avoiding or cleaning immediately…two obviously superior options that will, hopefully, be used in the future).
View BlasterStumps's profile
BlasterStumps
705 posts in 462 days
#2 posted 09-23-2017 05:07 PM
can you remove the red pads from between the jaws. they will be tight but I think they will slide out with a little force. Once they are out, there should be enough slack for the threads to work.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View Clarkie's profile
Clarkie
455 posts in 1863 days
#3 posted 09-23-2017 05:12 PM
Try tapping the bottom of the bottom jaw with a mallet. Next, wedge a flat putty knife between the jaws and slowly and easily pop them apart.
View Rich's profile
Rich
2962 posts in 612 days
#4 posted 09-23-2017 05:19 PM
The jaw locks against the bar by cam action back and against it. Try taking a heavy non-marring hammer, like a dead blow, and rap on the part of the jaw that the handle goes into. Clarkie’s suggestion to wedge the faces apart down near the bar might help it pop open once the jaw unlocks from the bar.
View Jim Jakosh's profile
Jim Jakosh
20589 posts in 3128 days
#5 posted 09-23-2017 05:39 PM
Try smacking that black piece( that the screws goes into) with a block of wood and a hammer to release the cam action that holds it tight. Then you might be able to pry it apart easily.
Jim
View cabmaker's profile
cabmaker
1735 posts in 2831 days
#6 posted 09-23-2017 05:39 PM
The only suggestion i have is to throw it in the trash and go get you some pipe clamps
4998 posts in 2516 days
#7 posted 09-23-2017 06:03 PM
I would have suggested some of the remedies already mentioned, but for cleaning the glue of the bars, a heat gun really works well. It softens the glue allowing it to be easily removed.
View BB1's profile
BB1
#8 posted 09-23-2017 07:02 PM
And…did a little tapping with a hammer, wedged a putty knife between the heads…this allowed me to slide off the red face AND that was all it took. A big thank you for all the suggestions. Once again, LJ to the rescue!
View bondogaposis's profile
bondogaposis
4755 posts in 2374 days
#9 posted 09-23-2017 07:49 PM
- BB1
The best way is to use a heat gun and a putty knife. Once you get them clean, wax them, and in the future glue will pop right off. I’ve learned the hard way that the best practice is to wax them when they are new and unused.
-- Bondo Gaposis
View BB1's profile
BB1
#10 posted 09-23-2017 09:52 PM
I think I have most off. Do you just use paste wax?
- BB1
The best way is to use a heat gun and a putty knife. Once you get them clean, wax them, and in the future glue will pop right off. I ve learned the hard way that the best practice is to wax them when they are new and unused.
- bondogaposis
View pontic's profile
pontic
591 posts in 631 days
#11 posted 09-23-2017 09:59 PM
Parallel clamps shouldn’t be over tightened. Don’t force warped pieces together with it or drive tight tenons in with them.
Those things are what pipe clamps are for.
-- Illigitimii non carburundum sum
View EricLew's profile
EricLew
207 posts in 1388 days
#12 posted 09-23-2017 10:09 PM
For the glue issue, although I haven’t had to do it, I have heard a wire brush works well. Covering the bars with craft paper or painters tape prior to glue up will eliminate the issue
-- I love the smell of coffee in the morning, and sawdust in the afternoon
View syenefarmer's profile
syenefarmer
492 posts in 3103 days
#13 posted 09-23-2017 11:32 PM
Any wax that doesn’t contain silicone will be OK to use.
View Kazooman's profile
Kazooman
1024 posts in 1975 days
#14 posted 09-23-2017 11:53 PM
Parallel clamps shouldn t be over tightened. Don t force warped pieces together with it or drive tight tenons in with them.
- pontic
I can’t resist. Please forgive any unintentional aspersions. I always thought that eliminating warped pieces and tight tenons were a part of the craft. Clamps are what we use to hold the pieces we have shaped in the proper alignment while the glue dries. Using any clamp to force a piece into submission is not a good idea.
View TheFridge's profile (online now)
TheFridge
9606 posts in 1508 days
#15 posted 09-24-2017 12:21 AM
Johnsons paste wax paper works for me. It’ll pop right off.
