Help, I need a part.
Forum topic by woodklutz posted 01-29-2011 03:50 PM 2396 views 0 times favorited 2 replies Add to Favorites Watch
View woodklutz's profile
woodklutz
221 posts in 2640 days
01-29-2011 03:50 PM
Topic tags/keywords: httplumberjockscomtopicsnewrouter part
Hey LJ’s, who else could I turn to for this request. I have an old Master Mechanic Router model MM 8510 that has a missing collet. This is a 1 3/4 hp router that I have had for at least 20 years, but it worked and money is tight so if I am able to I would like to fix it. I called True Value who was the seller of MM but no help. I am sure that tons of the same router were made under other names, but they could or would not try to cross index to see if there was a matching part. Thank you to all who take the time to read this.
Lumberjocks Rule!
-- honing my craft one mistake at a time.
2 replies so far
View RTim's profile
RTim
60 posts in 2564 days
#1 posted 01-29-2011 04:05 PM
Try part #25 at http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/skil/MM8510_TYPE_1 From what you posted, this should be the part you need.
The Master Mechanic series is a private label built by Skil.
Good luck!
-- Tim from MA -- "Well done is better than well said." - Benjamin Franlin
View GMman's profile
GMman
3902 posts in 3569 days
#2 posted 01-29-2011 04:26 PM
