Light set up for spraying
Forum topic by rwe2156 posted 09-23-2017 11:14 AM 293 views 0 times favorited 3 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
2799 posts in 1386 days
09-23-2017 11:14 AM
Newbie here I’m doing my first spray job and one challenge I’m facing is lighting.
I don’t have a dedicated spray booth I’m just using a portable incandescent light stand.
Looking for ideas andd what you all have. I’ve thought about making something with flourescents.
It needs to be 1) portable and 2) easily stored. Thx.
3 replies so far
View Jerry's profile
Jerry
2552 posts in 1553 days
#1 posted 09-23-2017 11:36 AM
You need to have a hard incandescant bulb shining on your workpiece, it will reveal all of the flaws in your paint and help you get an even coat. Test first. Always test first.
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
View OSU55's profile
OSU55
1522 posts in 1895 days
#2 posted 09-23-2017 12:10 PM
In addition to shop lights, I use the aluminum bell shaped clip on lights from the bbs. I have several and clip them where needed, including a few ” clip stands” made from 2×4. I also attached some cheap angle brackets (fromm bbs) from the ceiling the lights clip to. Put a small nut and bolt through the bracket so the clip doesnt slip off.
View TungOil's profile
TungOil
841 posts in 400 days
#3 posted 09-23-2017 12:15 PM
I use one or two 500W halogen work lights on stands. You can see one in this image in the back of the temporary spray booth that I set up in my shop when I need to spray something. The key is to get raking light so you can see the surface imperfections clearly. I like to work off a lazy susan arrangement when possible so I can rotate the piece being sprayed. This allows me to always direct my overspray towards the exhaust fan as well as not have to move the light constantly to inspect the freshly sprayed surfaces. On a piece like the table base below, it’s a real time saver.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
