How do you calculate (Revisited) staved angles on segmented rings
« back to Woodturning forum
Forum topic by Jack Lewis posted 09-22-2017 06:18 PM 2041 views 1 time favorited 7 replies Add to Favorites Watch
View Jack Lewis's profile
Jack Lewis
342 posts in 1278 days
09-22-2017 06:18 PM
Topic tags/keywords: staves segmented spread sheet
I think the method of flat segmented rings has been solved with complete clarity. E.I.. the sleds and “Miter Set” devices. So I don’t want to revisit that.
When I started to calculate the angle between staved segments, the problem of blade angle was added to the miter angle. When a blade angle of 90o (90 degs.) vertical to TS bed is used the stave angle is vertical. I wanted, as an example, a stave that was 45o from vertical. The 90o blade angle didn’t work (naturally) and just guessing 45o blade angle wasn’t the answer either. As long as I was intending to make various segmented vessels of different numbers of staves and different angles, I needed a formula or spreadsheet to calculate the different values and I didn’t want to go through the trial and error with just guessing and trying to fine tune each one.
I think I have the solution but I want someone to confirm or disprove it.
Starting with a vertical stave the blade angle is calculated as (360o/# segments) or in the proven case of 12 segments it is 15o.
If I determine that the stave angle be 0o then the blade angle has to be 90o. This is the same as regular segments.
I then deduced that a 15o difference in blade angle could make a difference of 90o stave angle.
Which became a total of 75o of blade difference or a value of 75/90 or .8333
I then multiplied the value (.8333) to the difference of stave angle from 90o and produced a new blade angle.
Staved Vessel Blade Angle Calculator of jack Lewis
In spreadsheet form A B C D E
1 Stave change Segment angle f/ verticle Blade angle from vert. Segments Per deg. of change from vert.
2 30 90 15.000 12 0.8333333
3 60 40.000
or in SS formulas
2 B2-B3 90 360/d2/2 variable 75/90
3 variable (A2 x E2) + c2
D2 is the number of staves and can be changed
B3 is the angle of the stave from vertical and can be changed
This worked at changes of stave angles 90o, 0o , and 4 and 12 segments so I believe it is fairly accurate at all in between. This blade angle would still require the aforementioned jig to align the stave blank to cut the required segment angle.
If anyone differs or has other ideas PLEASE either reply or PM me. I want this to work and work right. I am tired of wasting material with trials.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
7 replies so far
View Nubsnstubs's profile
Nubsnstubs
1422 posts in 1930 days
#1 posted 09-23-2017 12:37 AM
HUH?? Jerry (in Tucson)
Jack Lewis
#2 posted 09-23-2017 01:28 AM
What’s the matter, too deep for you?
View Loren's profile
10477 posts in 3848 days
#3 posted 09-23-2017 01:44 AM
This guy appears to have the trig worked out:
http://www.tahoeturner.com/instructions/pdf/handout.pdf
I used to make conga drums when I was
younger. The critical difference was the inside
face was not a show face so the angles I used
were fudged to close the joints on the outside
and fill gaps on the inside. I was familiar with
the trig at the time but never perfected its use
once I got close enough for what I was building.
View Woodknack's profile
Woodknack
12430 posts in 2580 days
#4 posted 09-23-2017 01:59 AM
If I understand what you want to do, M. Wandel made a handy chart for staves.
http://woodgears.ca/miter/
http://woodgears.ca/miter/splayed_miters.pdf
View roofner's profile
roofner
126 posts in 2483 days
#5 posted 09-23-2017 02:12 AM
Your original formula was wrong but you got the right answer. should be 360 divide by number segments divided by 2 because its the complement of the angle to get 15 degrees. I can not verify what your trying to prove because . I’m not familiar with rest of the problem with the staves.
Nubsnstubs
#6 posted 09-23-2017 03:55 PM
What s the matter, too deep for you?
- Jack Lewis
Heck yeah, man. I learnt that 2+2 = 4, and 2×2 also = 4. That just about blew my mind. I haven’t been the same since. But when it came to subtracting 2 from 2, and arriving at 0, I was a goner. Don’t even get me started on division….. hehehe…....... Jerry (in Tucson)
View CharlesNeil's profile
CharlesNeil
2457 posts in 4070 days
#7 posted 09-23-2017 04:45 PM
pretty sure this wont help , but Maybe .. its a really old video but what the heck , making a bucket .
https://www.youtube.com/watch?v=3z4dMBNCSAg
