Mitre saw blade tpi
Forum topic by keef_ca posted 09-22-2017 12:45 PM 702 views 0 times favorited 19 replies Add to Favorites Watch
View keef_ca's profile
keef_ca
8 posts in 447 days
09-22-2017 12:45 PM
Topic tags/keywords: question mitre saw blades
hello all
My spiffy new Dewalt mitre saw was shipped with a Dewalt 60tpi “fine finishing” blade. Is this appropriate for general use? I was told to get a combination blade, either 40 or 60tpi.
I inherited a new and really nice Freud so right now the 60 is my go-to blade. I do only small projects, nothing really demanding or fine (yet….). Right now a lot of 2×4 and plywood projects. No ripping.
Do I need an another blade?
thanks, guys
Bj
19 replies so far
View Firewood's profile (online now)
Firewood
524 posts in 1834 days
#1 posted 09-22-2017 12:58 PM
Yuo dont need a combo blade sine a miter saw is inherently a crosscut saw. The 60 tooth that came with is fine for general purpose work. There are blades made specifically for miter saws and cross cut operations. if your Freud blade fits that catagory, save it for when you need extra clean cuts.
-- Mike - Waukesha, WI
View Mainiac Matt 's profile
Mainiac Matt
8553 posts in 2528 days
#2 posted 09-22-2017 01:16 PM
Circular saw blades are not rated by tpi (teeth per inch), but rather the total number of teeth. And the # teeth needed for smooth cuts depends greatly on the blade diameter.
Are you talking about 10” or 12” blades?
-- I yam what I yam and that's all what I yam
keef_ca
8 posts in 447 days
#3 posted 09-22-2017 01:21 PM
They are 12” blades. The Freud is 100tpi so I’m saving that for future projects as my skills develop. Although I may use it for a molding job I have coming up.
Thanks, BJ
keef_ca
8 posts in 447 days
#4 posted 09-22-2017 05:07 PM
thanks for the info
View William Shelley's profile
William Shelley
595 posts in 1669 days
#5 posted 09-22-2017 06:31 PM
I know I’m being super pedantic here, but as Matt mentioned, “tpi” (teeth per inch) is not how circular saw blades are measured. You just count the total teeth. So a 60-tooth blade has 60 teeth around the rim.
If you had a 12” blade that had 100 teeth per inch, it would have 3,800 teeth. I don’t think you want that.
It may seem like an irrelevant distinction, but it will save you a lot of embarassment and/or confusion later on if you get it right now. Otherwise, you might ask for a “24 tpi blade” and someone will hand you a reciprocating blade for cutting metal.
-- Woodworking from an engineer's perspective
View CharlesA's profile
CharlesA
3351 posts in 1997 days
#6 posted 09-22-2017 08:37 PM
I keep a 12” 80 tooth blade on mine all the time, and I’m amazed how well it has held up (Freud). I only pull out another blade if I’m doing a lot of treated lumber. Otherwise, it does walnut and 2×4’s.
View patcollins's profile
patcollins
1687 posts in 3065 days
#7 posted 09-22-2017 08:57 PM
If you are cutting 4×4’s or decking boards you are probably going to want a general purpose blade but for trim work you are going to want a trim blade. Match the blade to what you are cutting, not what type of saw you are using.
CharlesA
#8 posted 09-22-2017 09:01 PM
If you are cutting 4×4 s or decking boards you are probably going to want a general purpose blade but for trim work you are going to want a trim blade. Match the blade to what you are cutting, not what type of saw you are using.
- patcollins
True, but at least in my case, changing my miter saw blade is a pain, so I keep my 80 tooth on there unless I’m building a deck or the like. I’d rather change a bandsaw blade . . . twice.
keef_ca
8 posts in 447 days
#9 posted 09-23-2017 12:48 AM
- patcollins
What is different about a trim blade? Before I spend $90 I really want to be sure of things. In a few cuts I made the Freud made some ultra smooth trim cuts.
always somthiing I guess
Bj
keef_ca
8 posts in 447 days
#10 posted 09-23-2017 01:04 AM
- patcollins
Matching the blade and not the saw is good advice. I checked my 12” Diablo and they say its good for furniture making and so on….to trim. I’m fortunate.
thanks, Bj
keef_ca
8 posts in 447 days
#11 posted 09-23-2017 01:11 PM
If you had a 12” blade that had 100 teeth per inch, it would have 3,800 teeth. I don t think you want that.
- William Shelley
Good call. I totally missed that one. 3,800 teeth would be excessive.
Bj
View Gene Howe's profile
Gene Howe
11063 posts in 3628 days
#12 posted 09-23-2017 01:49 PM
You’ll get the best results from a blade made specifically for miter saws. The tooth angle is different. Mine’s a 10” and it’s an 80 tooth. But, it hasn’t seen construction lumber.
Stay away from thin kerf blades. Too much deflection in a 10” and, I’d imagine it’d be worse with a 12”.
If you want a better blade, consider Tenryu. Better grade of carbide, more of it, balanced and lasts far longer between sharpenings.
keef_ca
8 posts in 447 days
#13 posted 09-23-2017 02:00 PM
Stay away from thin kerf blades. Too much deflection in a 10” and, I d imagine it d be worse with a 12”.
- Gene Howe
as I sat comfortable that my Diablo thin kerf blade was a good purchase. I just cannot get this right.
I had a couple of cheap big box store blades (Rona like HD) that I just gave away thinking all I needed was my Dewalt blade the mitre saw was shipped with and my new Diablo.
I need a break from all this….
Bj
CharlesA
#14 posted 09-23-2017 02:10 PM
The deflection of thin kerf blades, imho, is a bit overblown.
Gene Howe
#15 posted 09-23-2017 03:04 PM
- CharlesA
It happens a lot with angled cuts in thicker (8/4) hardwoods. Not so much with 90 degree cuts.
