To build a router table or to buy one?
Forum topic by Chris_T posted 01-28-2011 11:47 PM 6337 views 0 times favorited 33 replies Add to Favorites Watch
View Chris_T's profile
Chris_T
94 posts in 2909 days
01-28-2011 11:47 PM
I was looking at buying a Bench Dog contractor router table. I think it would be way cheaper to just build one, maybe a small cabinet like one. Would you buy or build one and why? If I build one does it need a lift, what does a lift do, what is the advantage? Is it better to build or buy a fence?
33 replies so far
View Dan's profile
Dan
3630 posts in 2995 days
#1 posted 01-29-2011 12:04 AM
I would build one. There are many many different plans available for building router tables, from super basic to really fancy. You also get the joy of building it.
Buying one would be quicker and easier but I think you will find most people build their own.
-- Dan - "Collector of Hand Planes"
View live4ever's profile
live4ever
983 posts in 3125 days
#2 posted 01-29-2011 12:21 AM
Like Charlie said, the advantage of building one yourself is designing it EXACTLY how you want it to be and filling your own personal needs. If you find yourself simply copying a commercially available design, it probably won’t be worth your time because you won’t save much cash. But when you build it yourself, you might be able to incorporate many different ideas into one table/cabinet.
View SteveW's profile
SteveW
394 posts in 2973 days
#3 posted 01-29-2011 12:21 AM
Build your own, build your skills, build your confidence…
-- On the eighth day God was back in His woodworking shop! SteveW
View Brian024's profile
Brian024
358 posts in 3515 days
#4 posted 01-29-2011 12:34 AM
Build it.
View surfin2's profile
surfin2
51276 posts in 3251 days
#5 posted 01-29-2011 12:51 AM
Build your own, then you’ll have what you want, the way yo want, not what they’ll give you…
-- Rick
View richgreer's profile
richgreer
4541 posts in 3189 days
#6 posted 01-29-2011 01:04 AM
In general, I advocate building versus buying most of the time. On this issue it is a closer call. There are some fence systems that are much better than anything I can make (Incra or Freud). I also think the table tops available are better than anything I can make. What I insist on making is the stand/cabinet that the table top sets on.
View Loren's profile
10477 posts in 3763 days
#7 posted 01-29-2011 01:12 AM
I’ve built a few and owned a few. Each had its strong points.
I built my own fences always. I’ve seen some commercial ones that
were pretty cool, but none offered features I couldn’t replicate
with a little ingenuity.
I’ve never felt enough need for a lift to go to the trouble of buying
one. The Milwaukee routers have a built-in topside-adjustment hole.
The difference between a router table fence and a table saw fence
is the table saw has to have parallelism to the miter slot. The router
fence can be clamped at any angle to the table. The Incra/Jointech
jigs are cool, but not fences per se, even though fences are often
sold with the jigs. They can do some spectacular looking joints but
whether you’ll use those types of joints depends on your aesthetic
and philosophical approach to woodworking.
You’ll be mad when you carve up your expensive fence with a router
bit or drop it and break off a corner – But when it is one you whipped-up
yourself you’ll be like me: “ce la vie”
View knotscott's profile
knotscott
8120 posts in 3490 days
#8 posted 01-29-2011 01:16 AM
The only one I ever bought was a piece of junk (even to a newb)...I gave it away less than a year after I bought. I’ve since made one for every saw I’ve owned (wing mounted). It’s fairly inexpensive to do, it’s a great learning experience, and you can make them with the features you like best. I’ve made fences and purchased fences…currently using a modified HTC/Jet router fence attachment on my Jet Exacta II fence.
Chris_T
#9 posted 01-29-2011 05:15 AM
Well you guys talked me in to building one. I’ve already got the plans drawn out, now I just have to get it done.
knotscott
#10 posted 01-29-2011 07:55 AM
Good call IMO….it’s typically an afternoon or so (with some tweaking…). Enjoy!
surfin2
#11 posted 01-29-2011 08:54 AM
Don’t waste your money on the (Rockler) Deluxe Router Station Hardware Kit…
It’s not worth it…
-- Rick
View bigike's profile
bigike
4054 posts in 3403 days
#12 posted 01-29-2011 04:48 PM
Me i would build it and just splurge on the fence this way you get a table with all the storage you need and then some. It fits in your shop no matter what. I like the incra fences for the accuracy and dependability of repeatable cuts i would use a lift in conjunction with the incra fence just for better accuracy. I would build an out feed table mounted router setup rather than a stand alone, just for more space. All in all i think building one will be cheaper and much better looking than anything store bought. GOOD LUCK in any venture.
View Jonathan's profile
Jonathan
2608 posts in 3165 days
#13 posted 01-29-2011 05:00 PM
Let us know how the process goes for you.
I was contemplating the same decision a couple of months ago, and have since decided to build my own. Don’t know when, but it’ll help me build a few skills, as well as let me make it exactly how I want it. I won’t be constrained by, or have to settle for a commercial design. I plan on adding a lift as well, enclosing the router for noise and dust collection purposes, etc. Beyond that, and rough dimensions, I haven’t decided on number of drawers, etc. yet.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View Lee Barker's profile
Lee Barker
2170 posts in 2965 days
#14 posted 01-29-2011 06:41 PM
A router table looks daunting at first but the recipe is very basic.
1. Build four legs of two boards each, sort of “angle iron” like.
2. Glue an 8” block in one end of each one.
3. Build a box with a drawer and doors or two drawers. Set it on the blocks and attach it to the legs.
4. Square the leg tops and frame them.
5. Build your top and hinge it on the back.
I have built several and even taught classes in which the students built their own. We never even considered buying a fence—that just seems like folly. We did buy the insert but that was all.
With the hinged top you can tilt it open (use the prop of your choice—I used a hydraulic cylinder from a hatchback) and adjust the the bit height easier than squatting down and turning a crank.
I’ll post pics if you want.
Kindly,
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3273 days
#15 posted 01-29-2011 08:26 PM
Since nobody has mentioned it, I have to say that one of the best purchases I’ve ever made was my Benchdog router extension wing for my table saw. If you have a table saw that can support it, especially if your shop is space-challenged, it’s hard to ignore this (or other make extension) as an option.
Similiarly, I think the idea of dropping it into an existing workbench has some real advantages.
Building a stand-alone router table is cool, and I’m really envious of some of the ones I’ve seen here at LJ, but fundamentally you don’t need a whole lot to allow you to bring your work pieces TO the router.
-- jay, www.allaboutastro.com
showing 1 through 15 of 33 replies
