Radius Patterns
Forum topic by CaptainAhab posted 01-28-2011 11:23 PM 1636 views 0 times favorited 11 replies Add to Favorites Watch
View CaptainAhab's profile
CaptainAhab
214 posts in 2820 days
01-28-2011 11:23 PM
Am I the only one getting tired of looking for just the right bucket, paint can, dog food dish, etc to trace the radius I want!? A nail and string are not always an option. I have been looking online for quite awhile trying to find a set of CNC cut radius patterns…..with no success. My son thought he had found some so got them for my christmas….they were architectural scales !!!
Anyone with leads or sources for such a product, please let me (us) know.
Thanks,
Dave
-- Dave www.bluesagehues.com
11 replies so far
View cabmaker's profile
cabmaker
1735 posts in 2832 days
#1 posted 01-28-2011 11:44 PM
Are these to be for cab. door rails or what ? I normally am able to produce any radius I need with the help of an ext. table at the bandsaw. Are you needing templates with long term integrity or one time use ?
CaptainAhab
#2 posted 01-28-2011 11:54 PM
Permanent tool quality templates is what I am looking for. I don’t mass produce anything, it’s all one-off art. And I frequently need to draw single and multiple radii. I contacteda a plexiglass company, but they wanted around $300 to custom make a set! There has to be something out there.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3138 days
#3 posted 01-29-2011 12:00 AM
why don´t you make them yourself out of 1-2 mm 5 layer-airo-plywood
on a Bandsaw with a cirkelcutting jiig with a spring of 1 or 2 mm between the diameter
of the cirkels
a halfsheed shuold be enoff
take care
Dennis
CaptainAhab
#4 posted 01-29-2011 12:03 AM
Not out of the question, Dennis, but if I did it would have to be plexi. See-thru is a huge advantage at times.
Dennisgrosen
#5 posted 01-29-2011 12:15 AM
to be able to see is always a big advantice ….LOL
the other option from the plexi
is the two legged devider with a pencil in to draw cirkels with (can´t remember the english word for them)
but ells the airo – plywood is a great thing , I think you can get it down to 0,4mm thickness
and is very durable for pattern´s or other lightwaight construction´s , ....not sheap but dang its good …LOL
good luck with the hunt Dave
Dennis
View DrDirt's profile
DrDirt
4424 posts in 3765 days
#6 posted 01-29-2011 12:22 AM
I use these, but this might be too flimsy for what you want to do?
They are corner templates from Eagle America – they are see through.
http://www.eagleamerica.com/product/400-1120/saw_blades_and_accessories
View CampD's profile
CampD
1674 posts in 3509 days
#7 posted 01-29-2011 12:35 AM
I’ve made my own along the way.
I have a lot of scrape plexi (I save all of these scraps more then i do wood)
But! it never fails the one I’m looking to do I dont have yet.
I was a draftsman in a different time and have ”A lot” of templates, that i use to make the initial radii
-- Doug...
View Viktor's profile
Viktor
464 posts in 3441 days
#8 posted 01-29-2011 12:47 AM
How about a compass?
Was used for the last 7000 years.
CaptainAhab
#9 posted 01-29-2011 01:26 AM
thanx Dr Dirt, I will check that out. Viktor, not always possible, and I need up to 12” r at least. A friend of mine uses large compass but patterns would be much simpler for shop use.
View Dan Lyke's profile
Dan Lyke
1520 posts in 4148 days
#10 posted 01-29-2011 02:19 AM
If you’ve got a router with good dust collection, or someone willing to hold a vacuum to pull the plastic chips away from the bit, cutting your own out of Plexi or Acrylic isn’t that hard. The issue with plastics and routers is just keeping the plastic from melting and gumming up the tools, getting the bits clear helps a lot.
Although you might quickly discover that $300 is a bargain…
CampD
#11 posted 01-29-2011 09:47 PM
I use Trammel points to make my bigger radius’s.
You can make any length beam as needed.
Mine as shown you can replace one point with a pencil.
I make temp’s on the band saw, then finish with the disk sander
-- Doug...
