Router table insert made from hardboard?
Forum topic by Brett posted 01-28-2011 08:14 PM 2434 views 0 times favorited 3 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2652 days
01-28-2011 08:14 PM
I recently purchased a Ridgid router (R29302) and am planning to make a router table. Several plans online describe using 1/4-inch hardboard for the insert plate. Is hardboard going to be sufficiently rigid, or should I use a commercial insert plate?
-- More tools, fewer machines.
3 replies so far
View live4ever's profile
live4ever
983 posts in 2979 days
#1 posted 01-28-2011 09:14 PM
It would probably be ok, but the more support you can give it the better. Laminating 1/4” and 1/8” to make 3/8” would be even better.
Instead of having just a 1/2” ledge to support the plate, also give it corner support ledges (on opposing corners so you can still get the router out easily).
View bigike's profile
bigike
4050 posts in 3257 days
#2 posted 01-28-2011 09:43 PM
just screw it to piece of plywood, this way you don’t have to worry about leveling the plate. If your still gonna go with the plate use lexan.
Brett
#3 posted 01-28-2011 09:59 PM
bigike, my original plan was to screw it to the plywood (or MDF) top, as you suggest. I still may do that. I’m weighing the relative merits of having a stiff table top (with no insert, just a hole for the big) vs. having the ability to change the size of the openings easily (with rings on a commercial insert plate, or insert platess with different hole sizes). (I’m also trying to pinch pennies, which is why I asked about the hardboard insert.)
