| Forum topic by Peter | posted 640 days ago | 357 views | 0 times favorited | 15 replies | ![]() |
640 days ago |
Topic tags/keywords: powermatic jointer used equipment long-bed short-bed I have an opportunity to purchase a 2002 Powermatic 54A 6” jointer for $550 (new they cost $800). A good friend of mine is recommending that I look at the Grizzly or Jet which I could purchase for the same price but get a brand new machine. The bed on teh Powermatic is 66” long while the other units are ~ 44-46” long. Any help or thoughts would be tremendous. Thanks to all, ~Peter -- ~Peter |
640 days ago |
If you are going to buy a 6” jointer, I would buy the Powermatic and not look back! John -- John -- Racine, WI -- Woodworking..."It's not just a Hobby, it's an Adventure" |
640 days ago |
Run out and get the long bed today before it gets snatched up. Good used tools are hard to find. |
640 days ago |
I went through that same dilemma just recently. I just got my new Powermatic 54A set up last weekend. I certainly have not put much wood through it but, WOW !!, what a beautiful machine. The fit and finish are fantastic, from the base on up. The reasons I chose it over the Grizzly are the know quality, the long bed (and it is really long), and I personally did not want over 1.5 hp so I did not have to do any special wiring. I am sure I will like to have the extra 2 inches of width in the future, but for a hobby shop, it is a joy to own. The length of the bed is only really needed if you want to joint long boards. I would say grab it while you can. I doubt you will look at it someday and wish you had bought a cheaper new one. Steve -- Stevethepeeve -- I'm no rocket surgeon |
640 days ago |
Hi Peter, I bought the 54A about 3 years ago and while it works fine already wish I had gone with the 8”. The longer bed is an advantage when working with longer lumber but I am generally working with lengths of 5’ or less so it doesn’t come into play very often. With the 66” bed you can reasonably handle 9’ material but it will be awkward. As far as shortcomings go the 54A works fine for me. It did have some vibration problems but I aligned the upper and lower pulleys and it seemed to resolve the issue. Its dust collection is ok. I get some bypass from the knives and around the top of the tool but this is only a minor issue. My recommendation is to go with the 8” model. New or used is your choice. I tend to buy new vehicles so I go with new tools as well. With a used tool you are going to have some issues- bed rust, nicked knives, scratches, etc. If you can live with these then you will save some $$$. But, like buying a used car, I generally don’t buy used tools unless I get a real bargain. Hope this helps. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
640 days ago |
I bought a new Powermatic about 5-6 years ago and I couldn’t be happier with it. I’ve had no problems. I went through the set up when I got it and didn’t have to adjust anything. You get what you pay for and that’s why Powermatic is at the top of the line. I do more long than wide boards, mainly because quarter sawn white oak is hard to find in very wide boards. If I do have wide boards that I want to use, I just flatten on side with my hand planes and run it through my thickness planer. Like some have already said, just check it out good before you buy. -- Tim -- http://tmuli.com |
640 days ago |
I’d take a look at the Grizzly 8 -- DaveH - Boise, Idaho - “How hard can it be? It's only wood!” |
640 days ago |
My preference would be for a wider 8” model. The extra 2 inches of width would probably be more useful more often then the extra bed length. If you do decide to get an 8”, the Grizzly G0586 model has a 75” bed length. Wider and longer, but, a little more than $550.00 you can get the used 54A for. -- Mark |
640 days ago |
I own the Powermatic and it’s a great machine. But, as others have said, I wish I’d held out for an 8” model. No complaints about the Powermatic – I did the same modifications as Scott, above, to decrease some vibration issues. Runs smooth as silk today and the extra long bed is fantastic. Just wish I had more width. |
640 days ago |
Peter, I have that exact jointer, the PM-54A. I’ll start off with the positive, I really like this jointer. It is an excellent compromise of size, cost, and quality. When I say compromise it is not because of anything wrong with the jointer. For a 6 inch jointer I think it is the very best straight knife, 6 inch, dovetail ways, long bed jointer you can buy. Obviously I think it is the best, when I bought this jointer new I looked at all of the jointers in this class and spent my hard earned dollars on this one. So if you want a straight knife long bed 6 inch jointer I think the PM-54A is at the top of the heap. It is heavy, low vibration, the motor is strong, it is well made, every surface is flat and true. It is easy to adjust. It is all things good in it’s category. Notice how I keep putting in all those caveats, 6 inch, straight knife, and such. Because that is what it is, but that by no means means it is the best of what there is. Other immediately obvious choices are size, 8 inch instead of six, spiral head cutter instead of straight knife, parallelogram tables instead of dovetail ways, and even longer tables and bigger motors. For my shop size, wood working needs, shop space, etc, I was looking for just what I got, a 6 inch straight knife. If I had a bigger shop, maybe a little more money, worked on bigger projects, I’d probably have been looking for an 8 inch spiral head. So far the size, 6 inch vs 8 inch, has not really been a problem for me but I have pushed it right up the edges of the knives, 8 inch would be nicer than 6 inch. A spiral cutter will, in general, give less tearout on highly figured woods or wood with changing grain direction. The straight knives definitely are prone to tearout where the grain changes direction. That is probably my biggest beef with what I have. I work with a handful of exotic woods and as often as not I’ll have tearout in one section of the board or another. BTW the same problem exists on the other side of the board as soon as you take it over to your straight knife planer. A spiral cutter head jointer and planer would be nice. For me 8 inch would be nice, but the 8 inch jointers I looked at were quite a bit bigger and more money. Not worth it for me for the work I’m doing right now. The long table is nice if you have the room in your shop. I have jointed some longer boards and aside from the technical purpose of referencing the stock flat the longer tables are just nicer and easier to work on, more support in and out, easier handling of stock. In this class, 6 inch straight knife, I would recommend the PM-54A over any other. In it’s class I don’t think there are any shortcomings. What to look for in a used jointer is pretty much the same as you would for any piece of power equipment. - First, what is the general appearance, are there any obvious signs of abuse, is it dented, badly scratched, bent, warped, twisted, rusted, rattly, ratty, worn out. Or does it look clean and well maintained. If the tool looks like it has been neglected or abused, it probably has been. - Next check the technical issues. It’s a jointer, jointers make things flat, in order to do that they have to have flat reference surfaces. Take a known straight edge with you. Are the tables flat, and co-planer, or are they warped, cupped, dropping, twisted. Take a straight edge long enough to span the knives and get a feel for infeed to outfeed alignment. Check the fence, is it flat edge to edge and diagonal corner to corner. Jointers also make things perpendicular. Check that the fence can be set easily to 90 degrees to the tables. Can the fence be easily adjusted. Is anything sticky or bent or rusted or bound up. - Make sure the jointer is unplugged and check the cutter head, does it rotate freely. Any signs of abuse. Does it rattle or in any way feel loose or worn out. Grab the end of the cutter head and push it around. Is it tight or loose. - Check the knives. Are they nicked a little or a lot. A little bit of wear and tear is expected. Totally chewed up knives is a sign of abuse or improper use. - Since it is a piece of power equipment check the cord, motor, and belts. First the visual inspection. Look for any obvious signs like worn cords or worn belts. Make sure it is unplugged and rotate the motor by hand. Take the belt cover off, it comes off with two screws, and look at the belts and pulleys while you’re turning the motor. Listen and look, any sounds of grinding or wobbling? Smell the motor. You cant get right up to the motor, at least not very easy, but open the back panel on the stand and put your face right in there and give a big sniff. A little bit of insulation smell is normal. I whole nose full of burnt smell is not. - Finally turn it on and run it. How does it sound, how does it look. Put your hand on the table while it is running. How does the vibration feel. Run a piece of stock over it, how does it sound. Is it easy and smooth or do you have to fight it. If everything looked good and sounded good I’d put it in my truck and take it home. Good luck. |
640 days ago |
IMHO, you want the longest & widest bed you can get on a joiner, so if you have the space get as big as you can afford. I have a 6” and it seves me well, but there are times it would be nice if it was wider. -- If we learn from our mistakes, I'm getting a fantastic education. |
640 days ago |
I have an 8” jointer with a 76” long bed. If I had to choose between a length and width, I’d take the longer jointer without hesitation. -- http://www.north40custom.com -- http://north40studios.etsy.com -- |
640 days ago |
Powermatic -- Thos. Angle |
640 days ago |
Wow, thanks to everyone for the tremendous replies! This is all very helpful. Taking a quick survey there are 5 votes/recommendations to try to hold out for an 8” jointer. The two 8” Grizzly Jointers that were recommended look great but add $300 to the purchase price. I am afraid that when I consider the other power tools I hope to buy this year that extra cash is not in the budget. It is too bad that these things do not show up very often in the used market. Or at least they don’t anywhere near Charlotte. The other quick survey shows 7 possitive responses to buying a powermatic jointer and not one negative review other than some vibration from miss aligned pulleys, and that is very fixable. I will be keeping that in mind. Lastly, let me give a big thanks to Colorado Climber for the advice on what to look for, and how to look over, a used jointer. I will be following your suggestions. Best regards to everyone, ~Peter -- ~Peter |
640 days ago |
take the longer jointer. that gives you more support for longer boards and shorter boards alike. you never know when you may have to joint 8 ft boards for a grand dining table or something like that. a longer bed is more support. for most uses i think a 6” should be fine though. I am not saying this by personal experience but 6” should be fine unless you work with 7 or 8” boards. personally most of my hardwood boards are either 10 and 12” (too big for an 8” jointer) of 6” and under which would work on a 6” jointer. but you’ll have to make your own decision on whether you are going to use those extra 2”. my verdict is that it just depends on how you are going to use it and what you are going to use it for. P.S. also remember to perform checks on the jointer before you purchase it such as Coloradoclimber said. you don’t want to end up with a used machine that looks good on the outside but is totally useless as far as performance goes. |
640 days ago |
I bought a used Woodtek 8” jointer last summer and I love it. I find that I rarely use the entire width of the cutterhead, whereas I often appreciate the long beds. I’d go with the longbed jointer if I were you. -- Pat Mulry, Dallas, Texas || www.lonestarpokertables.com |
| Forum | Topics |
Woodworking Skill Share
2925 |
3958 |
258 |
954 |
225 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
