cleaning pitch off saw blade
Forum topic by buckbuster31 posted 09-20-2017 09:17 PM 1174 views 1 time favorited 24 replies Add to Favorites Watch
View buckbuster31's profile
buckbuster31
254 posts in 634 days
09-20-2017 09:17 PM
what does everyone like to use? I don’t want to buy the overpriced pitch remover but can if I need to.
24 replies so far
View Loren's profile
10477 posts in 3766 days
#1 posted 09-20-2017 09:30 PM
Household cleaners like simple green will
work. Mix whatever you have on hand
with water and soak the blade for awhile.
The pitch will come off with a nylon bristle
brush.
View clin's profile
clin
919 posts in 1115 days
#2 posted 09-20-2017 09:58 PM
409 works well for me.
-- Clin
18860 posts in 1975 days
#3 posted 09-20-2017 10:01 PM
I’ve used brake cleaner with good success.
View HapHazzard's profile
HapHazzard
116 posts in 987 days
#4 posted 09-20-2017 11:26 PM
Mineral spirits, turpentine, MEK… Whatever’s handy.
Next question is how to get it out of your shop rags.
-- Unix programmers never die; they just > /dev/null
View mudflap4869's profile
mudflap4869
1831 posts in 1578 days
#5 posted 09-20-2017 11:41 PM
When felling SYP trees we used to dip our chainsaws in kerosene and run them for a minute. Cleaned them up pretty good. That sap could clog up about anything it got on.
-- Still trying to master kindling making
View papadan's profile
papadan
3584 posts in 3487 days
#6 posted 09-21-2017 12:24 AM
I use some stuff called Goof Off I get at home depot.
View AlaskaGuy's profile (online now)
AlaskaGuy
4364 posts in 2428 days
#7 posted 09-21-2017 12:46 AM
brush.
- Loren
+1 I don’t care who says not to use it.
AlaskaGuy
#8 posted 09-21-2017 12:47 AM
- clin
+1
AlaskaGuy
#9 posted 09-21-2017 12:47 AM
- papadan
</blockquote +1
AlaskaGuy
#10 posted 09-21-2017 12:48 AM
I ve used brake cleaner with good success.
- firefighterontheside
I got some of that I’ll have to try it out next time.
AlaskaGuy
#11 posted 09-21-2017 12:49 AM
I have found most cleaners work.
View MickNM's profile
MickNM
8 posts in 378 days
#12 posted 09-21-2017 01:12 AM
I use a few drops of Dawn in hot water. Plastic bristle brush, wipe clean and dry.
View pintodeluxe's profile
pintodeluxe
5741 posts in 2932 days
#13 posted 09-21-2017 01:22 AM
Simple Purple (Simple Green Industrial formula) is amazing for cleaning blades. It is available in gallon concentrate at Home Depot for a reasonable sum, and it will last you a long time. Thin it one part Simple Purple to two parts water, and the pitch and resin will dissolve almost immediately.
Plus there is no risk of eroding the carbide teeth like there is with Simple Green (probably only an issue if you soak the blade for an extended period).
View Woodknack's profile
Woodknack
12336 posts in 2499 days
#14 posted 09-21-2017 02:18 AM
Citrus degreaser, like Zep. Takes the pitch off in about 60 seconds, twice that if it’s really bad. I spray it on, give it a minute, then brush it with a toothbrush. It’s acidic so you need to rinse with water or neutralize.
117203 posts in 3696 days
#15 posted 09-21-2017 03:25 AM
Washing soda, goof off, simple green.depends on how much you want to scrub.
