Ordered the woodriver guide rail system
Forum topic by Mike Gager posted 01-28-2011 06:11 AM 4498 views 0 times favorited 3 replies Add to Favorites Watch
View Mike Gager's profile
Mike Gager
665 posts in 3231 days
01-28-2011 06:11 AM
today i ordered the woodriver guide rail system from woodcraft. i actually ordered the pieces individually as they are on sale and saved about $10. also got the miter angle jig to go with it
heres the system
http://www.woodcraft.com/Product/2080310/28352/WoodRiver-Guide-Rail-4-x-8-Kit.aspx
it appears to be fairly new and i havent seen much about it so im kind of taking a chance on it but it looks like just what i need for an upcoming project where ill be needing to cut a bunch of sheet goods
has anyone used this system?
3 replies so far
View Loren's profile
10252 posts in 3612 days
#1 posted 01-28-2011 07:22 AM
Should be fine if you’re not in a hurry. The more costly systems like
Festool put the edge of the guiderail right on the cut line, so setting
up the cut is faster. With guides like the Woodriver you have to do
some math to set the guide to compensate for the offset of the
cutline from the edge guide. Some simple self-made plywood layout
jigs can make the process of measuring, marking, clamping and cutting
go a bit faster.
View tedth66's profile
tedth66
458 posts in 3153 days
#2 posted 01-28-2011 05:21 PM
Yes I have this system. I use it in combination with my Festool TS55 (track saw) so I can make a perpendicular cut on sheet goods. I like it a lot.
-- Ted
Mike Gager
#3 posted 02-04-2011 03:01 AM
finally got this in the mail today. everything looks real nice. i will do a review on it when i get a chance to really test it out
