Making a pencil post , bed post
Forum topic by CharlesNeil posted 09-20-2017 02:43 PM 736 views 0 times favorited 9 replies Add to Favorites Watch
View CharlesNeil's profile
CharlesNeil
2434 posts in 3991 days
09-20-2017 02:43 PM
I do my post a little different so I did a couple You Tubes on how I do it
This is tapering the post https://www.youtube.com/watch?v=RtnV8jm1kP8&t=25s
This is Chamfering the other 4 sides
https://www.youtube.com/watch?v=WoFDe5Qzln4
9 replies so far
117203 posts in 3698 days
#1 posted 09-20-2017 02:50 PM
Thanks for sharing that info Charles it’s a technique that could be a big head scratcher for many many folks.
you D man
View Monte Pittman's profile
Monte Pittman
29800 posts in 2459 days
#2 posted 09-20-2017 04:18 PM
Thanks sir. I need to make one of these.
View Joe Lyddon's profile
Joe Lyddon
10241 posts in 4173 days
#3 posted 09-20-2017 05:55 PM
Charles,
Thank you again for sharing your infinite Wisdom with us!
You are a GREAT help… and we appreciate it!
View mudflap4869's profile
mudflap4869
1832 posts in 1580 days
#4 posted 09-20-2017 06:29 PM
Very educational and you made it look easy. Thank you my friend.
-- Still trying to master kindling making
View Desert_Woodworker's profile
Desert_Woodworker
1591 posts in 1335 days
#5 posted 09-20-2017 08:12 PM
Thank you for your generous advice. I ran your project on a CNC forum; their advice was to use your method vs the CNC, the response was that your method, is faster and safe. I agree. :)
-- Desert_Woodworker
View bonesbr549's profile
bonesbr549
1576 posts in 3188 days
#6 posted 09-20-2017 08:50 PM
His way of doing is the best I’ve found. Used his dvd’s to make mine, worked like a charm and still going strong.
BTW Charles, I made mine in a california King and my supports are still not sagging with your “T” construction method. The Laminated rails are still just as strait as ever as well.
Cheers!
https://www.flickr.com/gp/22447246@N06/755q69
View pontic's profile
pontic
626 posts in 729 days
#7 posted 09-20-2017 08:57 PM
Charles; Show us how you Made that Jig!
-- Illigitimii non carburundum sum
View Kazooman's profile (online now)
Kazooman
1117 posts in 2073 days
#8 posted 09-20-2017 09:00 PM
Charles, Great video as always. I got to thinking if there wouldn’t be a way to make another table saw sled to make the final four cuts. It would need some sort of 90 degree “saddle” to hold the post in the proper orientation. The height of the saddle and the dowel pivot point would need to be adjusted accordingly. The best solution would be one sled that incorporates interchangeable pieces for the two operations. Would this work, or am I missing something obvious here?
CharlesNeil
#9 posted 09-21-2017 12:59 PM
Kazooman,
Your approach seems workable.
In the early days , i had similar to what your describing , the jig held the corner of the post 90 degrees to the saw table and I used a dado blade , to make the final taper , it took some experimenting to get the post in the correct orientation, but it worked.
