Dewalt DW625EK under a router table... which router lift?
Forum topic by steliart posted 01-28-2011 02:21 AM 10758 views 0 times favorited 6 replies Add to Favorites Watch
View steliart's profile
steliart
2595 posts in 2686 days
01-28-2011 02:21 AM
Topic tags/keywords: dewalt dw625ek router router table router lift
I am designing a router table which will be attached with my TS and use the TS fence as a common fence system. Space under the table is limited because I mast stay within the fence rail length.
The router that I just got is a Dewalt DW625EK 240V 2000W with fine high adjuster and I am wondering…
1st – If the fine high adjuster will be good enough to work under the table and how easy will this be (no expenses in this case) or
2nd – If I choose to go with a router lift, which router lift will be more appropriate or recommended for the Dewalt DW625EK.
3rd – Is there something else not so expensive that I can do.
Thank you in advance for all your replies
Stelios
-- Stelios L.A. Stavrinides: - I am not so rich to buy cheap tools, but... necessity is the mother of inventions
View Loren's profile
10390 posts in 3646 days
#1 posted 01-28-2011 04:04 AM
That’s a plunge router with a fixed motor – it won’t work with most
of the router lifts on the market. Look at the Lee Valley “Router Jack” –
a lift system for this type of plunger.
steliart
#2 posted 01-28-2011 05:16 AM
Actually there was one at Woodpeckers called Plungelift but I cant find it on there site even though you can google it to them and new one coming out name Unilift.
View TheHarr's profile
TheHarr
116 posts in 3537 days
#3 posted 01-28-2011 05:56 AM
Hey Setliert, here’s a link to a LJ discussion on router lifts. See my comments and pictures there.
http://lumberjocks.com/topics/23047
-- The wood is good.
steliart
#4 posted 01-28-2011 06:53 AM
TheHarr
The Dewalt DW625EK is a plunged router the Jessem lifts are for fixe-base routers or am I missing something here?
Thanks
View ajosephg's profile
ajosephg
1880 posts in 3559 days
#5 posted 01-28-2011 06:54 AM
I have the 625 in my table and use it with the fine adjuster. The only disadvantage that I can see is that it takes a while to make big adjustments. But, as a hobbyist, I have more time than money.
I tried removing the springs, but put them back in because when you lower the router it doesn’t go down smoothly.
-- Joe
steliart
#6 posted 01-28-2011 07:16 AM
ajosephg
Thanks for the input Joe.
My reason for a lift is that I have a back problem and bending alot is not the best for me. I am considering even that motorized driver DIY router lift that Nixon did from Eagle lake Woodworking because my space is tight as I have to keep the router plate at the inside edge of the table so that the TS fence rail riches it.
But it’s good to know that the fine adjuster can do the work.
