What is this safety switch called?
Forum topic by cessna310 posted 09-20-2017 06:05 AM 1728 views 0 times favorited 13 replies Add to Favorites Watch
View cessna310's profile
cessna310
2 posts in 2114 days
09-20-2017 06:05 AM
Is there a switch that can be used on a cabinet saw that will turn off in event of a power outage and will not allow the saw to restart upon power restoration until the saws power switch is physically turned on. In other words the saw won’t accidentally start when the shops power is restored.
Larry
13 replies so far
View MrUnix's profile
MrUnix
6887 posts in 2316 days
#1 posted 09-20-2017 06:08 AM
Mag(netic) switch… starter (NEMA or IEC)... LVC (low voltage control)... take your pick.
View Carloz's profile
Carloz
1147 posts in 709 days
#2 posted 09-20-2017 11:33 AM
How many power outages you have? Unless you are a production shop just turn the switch off after that once in lifetime event when the power outage happens just when you cut wood.
Carloz
#3 posted 09-20-2017 11:35 AM
- MrUnix
You’d better skip the parenthesis as magswitch is a very useful but completely different switch.
View Sparks500's profile
Sparks500
197 posts in 448 days
#4 posted 09-20-2017 11:59 AM
View 08k8's profile
08k8
11 posts in 367 days
#5 posted 09-20-2017 01:22 PM
My Jet cabinet saw has a “magenetic” switch. It is basically a relay that turns the motor on. The on button that you push sends electricity to the relay coil. The Off button is normally closed and breaks the coil circuit when you press it. If you lose power, you would need to re-initiate that sequence.
-- Too many hobbies.
View Nubsnstubs's profile
Nubsnstubs
1362 posts in 1847 days
#6 posted 09-20-2017 05:06 PM
- Carloz
That’s easy to say, Carlos, but real life is a lot different that kicking back and making the statement you just made. One power outage is one too many. The magnetic switch prevents one from getting hurt by being distracted by said power outage trying to find out why there is no power. You don’t need the power failure to come from the source, the power company. A worn out outlet that the plug goes into without any effort could allow the plug to fall out, causing a failure. Even someone hooking a foot on a cord lying on the floor causes a power failure. Even on a construction site, someone could disconnect your power and cause you not to turn off the switch because you need to find why you lost power. All the above are distractions that can cause a person to lose focus. There are probably a whole bunch more instances that I didn’t mention, but these I’ve experienced….... Jerry (in Tucson)
MrUnix
#7 posted 09-20-2017 06:04 PM
- Carloz
“Magswitch” is a company that sells magnets, not switches. “Mag Switch” is an often used shorthand spelling for “Magnetic Switch”, hence the parens.
- Carloz
Besides the points Jerry makes, a true magnetic switch (aka: starter) has other benefits as well… such as the ability to run a remote (or multiple) kill switch easily using low voltage instead of line voltage. It also allows the use of larger motors and their increased current demands. Most ‘toggle’ switches can’t easily handle a 3hp or greater motor without arcing and tearing up the smaller contacts than what is found on a properly sized contactor. That is what they were designed for. The power-out safety feature is just an extra benefit due to the design.
View papadan's profile
papadan
3584 posts in 3486 days
#8 posted 09-20-2017 06:20 PM
- 08k8
Exactly!
runswithscissors
2818 posts in 2142 days
#9 posted 09-21-2017 01:18 AM
Grizzly has magnetic switches. Cost around $80 or so. Jerry in Tucson lists several very valid reasons to have one.
woodbutcherbynight
5545 posts in 2526 days
#10 posted 09-21-2017 01:56 AM
Try this one, I have two I installed both on Delta contractors saws. Works well and is cheaper now then when I got them awhile back.
LINK
MrUnix
#11 posted 09-21-2017 02:00 AM
LINK
- woodbutcherbynight
Keep in mind that the switch above provides no overload protection… it would be fine for a motor that has built in protection, but most cabinet saw motors rely on external protection provided by the starter. Just saying.
woodbutcherbynight
#12 posted 09-21-2017 03:11 AM
Oops missed he was talking about a cabinet saw.
cessna310
#13 posted 09-22-2017 08:50 PM
A big thanks to all respondents, I now have my answer.
Larry
