how to measure cabinet frame opening for double doors
Forum topic by bluephi1914 posted 09-20-2017 02:14 AM 3727 views 0 times favorited 12 replies Add to Favorites Watch
View bluephi1914's profile
bluephi1914
84 posts in 1535 days
09-20-2017 02:14 AM
I am trying to figure out the formula for double doors for this particular opening . I am using the pictured hinges.
Opening measurements are 19 7/16 wide – 26 5/8 tall
the hinges are 1/2 inch overlay
thanks in advance for any help.
I know that there should be a 1/16 gap between the center of the doors, but im not sure how to calculate that.
-- Jack of all trades and a master of most of them.
12 replies so far
View barada83's profile
barada83
88 posts in 1363 days
#1 posted 09-20-2017 02:44 AM
((total width + 2overlay)-1/16)/2 In words – take total width, add the overlay to that for both doors (1/2” overlay2 is 1” extra). From that, subtract your center gap. Then divide that by 2.
-- Mike
View TungOil's profile
TungOil
1040 posts in 672 days
#2 posted 09-20-2017 03:37 AM
Mike is correct on the math, but I’ll suggest a slight variation to fitting these doors that will help account for any accumulation of errors in the build of the carcass and doors. If you make the doors slightly wide, you can sneak up on the gap by taking light cuts with a jointer or hand plane and fit the gap. By doing it this way, you can correct for any minor errors in the sizes of the parts and mounting of the hinges that accumulated in the build.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View JBrow's profile
JBrow
1366 posts in 1097 days
#3 posted 09-20-2017 04:34 AM
bluephi1914,
I will add that beveling the meeting edge of each door (where the doors meet in the middle) could help prevent binding as the doors are opened and closed. The bevels could also make short work of fine tuning with a hand plane after the doors are mounted to get the doors to close just right. A 5 degree bevel seems to work.
View Bumpy's profile
Bumpy
40 posts in 658 days
#4 posted 09-20-2017 10:49 AM
For over 20 years I have used the following:
OW +15/16 divide by 2
I use Blum inserta cup hinges. The above allows for 182 OL and the hinge offers the fine adjustment
bluephi1914
#5 posted 09-20-2017 05:15 PM
- barada83
this worked like a charm… had to take a little off with my jointer… like another 16 or 32… but it worked out !!
View rwe2156's profile
rwe2156
3135 posts in 1657 days
#6 posted 09-20-2017 05:24 PM
if you are rabbetting the doors for a center overlap you have to figure that in too.
View Desert_Woodworker's profile
Desert_Woodworker
1624 posts in 1391 days
#7 posted 09-20-2017 08:19 PM
Mike is correct on the math, but I ll suggest a slight variation to fitting these doors that will help account for any accumulation of errors in the build of the carcass and doors. If you make the doors slightly wide, you can sneak up on the gap by taking light cuts with a jointer or hand plane and fit the gap. By doing it this way, you can correct for any minor errors in the sizes of the parts and mounting of the hinges that accumulated in the build.
- TungOil
ditto +1
-- Desert_Woodworker
bluephi1914
#8 posted 09-21-2017 02:31 AM
finished project… thanks all for the help !!!
Desert_Woodworker
#9 posted 09-21-2017 02:32 AM
Nice job!
View AlaskaGuy's profile
AlaskaGuy
4650 posts in 2486 days
#10 posted 09-21-2017 02:37 AM
Looks perfect form where I’m sitting.
View waho6o9's profile
waho6o9
8488 posts in 2753 days
#11 posted 09-21-2017 02:42 AM
Good job
Desert_Woodworker
#12 posted 09-21-2017 02:48 AM
Not so easy—- give us some close up pic’s both left and right….. :)
seriously how did you figure out “how did you make it work.”
